hey all i have a rb25/30det for sale heres a list of it, all i am in launceston can get hold of me on 0488784478
the head and bolt are bolted together
head has big tomei cams bigger springs vavles all that jazz 16 hour port job the car it came off made 370kwatw
rb30 bottom end with 141 ks got it all compresson tested befor i took out of the car come back all good
parts that need puttin on
brand new water pump ,timimg belt ,all new inlet manifold gasket kit
has stock turbo manifold, injectors, coil packs, afm, starter motor cross over pipe comes
just put brand new arp head stud kit in as well
heaps more iv forgotta cant thing now just get hold of me on my number above
price is 1600 i really need to move this on to buy something i want ,
also have a rb25det head with cams tapper covers turbo manifold in good cond 140ks 200firm need to move it all real fast
oh and i have a wolf 3d for rb20/25 plug and play with hand controller i am 750 firm doesnt worry me if this dont sell but not using atm cheers
  • 1 month later...
still got the engine?
got compression test results off hand? leakdown test done also?
did it sh!t a water pump or something to warrant the new parts for it? or the info given was from the separate previous motors?
might be keen, just need to know much much more.
send me a msg on 0459220530 and ill tell you everything about it a can
your pm's full up and I have a bunch of q's;
1. Was this engine ever running?
2. The timing belt is new but no tensioner/idler? As in you need to drill a hole to put one in, has this been done and the belt is the right belt to suit 25/30?
3. VCT Head - what have you done in regards to this?
4. Oil drain for head?
5. Oil restrictors?
6. Head checked out and passed crack test etc?
7. Heaps more that you have forgotten, but is there anything else you can tell me at all?
8. Loom?
9. New Water Pump - nissan or a/market?
10. Why selling?
11. Head and Block not actually together at the moment?
12. Compression on 30e was good, but can you remember what it was?
too much typing for sms'ing.
all the heads done ready to put to together the timing belt is already made to suit the motor has never been ruining , no loom, water pump is a new nissan one , head has been checked for crack and is all good ,
  • 5 months later...
How are the condition of the camshafts in the stock head? if they are good and you are willing to ship id like to purchase them. I live in Canada BC tho so shipping would most likely be expensive. Please get back to me at [email protected] as soon as possible
Address is V1B 2M6 Canada BC
Thanks
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
