be VERY careful if you purchase these lights. remember in the US they drive on the other side of the road, so the headlights are setup the opposite way. if you were to install their lights on your car, youd blind the oncoming traffic, and not be able to see the LH side of the road properly.
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5610045
One of V35 coupe owner here in WA got a black one. I think he said he adjusted the RH side to shine the light at lower level, same as the LH side one. I am going to check on this once he get back from holiday, and I might be getting one. :)
Typically, it's not totally legal in Australia.
Edited by Victor.T
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5610114
i already have 06 model lights imported from infiniti us installed on the car. it need little adjustment to three screws inside the light assembly. ferntree gully nissan qouted me 2500$ for each headlight which was not even projectors ,went to infiniti us website bought both left and right plus left hand side power window motor including shipping for 800 AU$ genuine and brandnew.
so back to question i think chrome one is better.
cheers
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611333
couldnt you just adjust the "toe" of the headlights so it goes in the other direction?
I dont think anything "modified" on our car is legal unless engineered. it really doesnt stop any of us.
Personal choice, is Black it would look nicer.
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611349
im not sure of the exact configuration of the US headlights, but generally the beam is modified by the projector itself, hence my warning.
anyway, looks like people are putting them on anyway and blinding on-coming traffic lol
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611374
so you'll make a few people blind, and potentially crash and die.. no biggy..
haha joke.. if they look good, I would just angle em a different way.
I'm probably doing the same damage having 8000k HID's without projector lenses so im not one to be a Hypocrite :D
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611390
The projectors themselves are different for left & right hand drives. The housing does not change. Inside the projector unit is a "cutoff" plate which controls high/low beam. This plate is angled in a way to bias the light beam away from oncoming traffic. No adjusting of the US projectors is going to prevent glare and using US spec headlights will void insurance and likely earn you a defect notice.
As for colour, you look like you have a Black on black scheme goin on. I'd go black bezel with chrome shrouds on the projectors.
Edited by mosoto
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611489
Yeah, it is a risk.
But they look nice. :P
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611582
not really, the difference is that our cars are designed to have HIDs from factory, we arent getting retro kit for an older car.
D2Rs are for our cars, D2S are for projector.
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5611588
nop u wrong mate , u have to loose a screw at the top and tighten the screw on the bottom of the projector holding bracket to make it look downwords.
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5612818
thats just the adjustment that all headlights have, he is talking about the actual beam projected outside the car.
have you ever noticed that the light is not straight? it goes up at the left. in the USA, it goes up at the right. if you drive with US headlights in australia, youll blind the people coming towards you.
ill find a picture somewhere.
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5612894
Exactly, Thanks Lain. Yes Awais, you may think you can adjust out the camber on the beam but even if you could you will not get correct aim and you will be rendering your headlights useless.
You should research the mechanics of the projector lights before you make comment, it makes you look noob :).
Besides, why risk voiding insurance. If you have a serious accident your insurance WILL NOT honour a claim if any parts on your car do not meet ADR. It will not matter if that part had absolutely nothing to do with the accident.
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5613017
yes but they are cheaper than he was quoted for the correct items that will NOT earn him a defect and void his insurance and they will impress the chicks why would he not buy them... (/sarcasm)
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5613050
oh to be honest I dont know what that is. i just bough universal replacements in 8000k, which will probably last a year. but meh..
haha Lain
https://www.sau.com.au/forums/topic/349128-altezza-lights/#findComment-5613058
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
