its more the drunken idiots id have to contend with throughout (while standing in line...). and im not sure they let cripples use firearms. lol.
ill see how i go.
Edited by scandyflick
Yep was good as always. Don't remember much after about 4pm, but apparently the wife picked Scandy, Whiplash and I up then Nick walked home from near my place, and Scandy played some pool at my place. Was fair drunk and stumbling around until midnight when I finally went to bed. Drank over 1lt of water during the night and woke up 100% on Sunday :)
There were many fine girls about, the food was good and the German beer was great.
lol that is the exact song I thought of when I read what Krishy wrote - classic quote from Stallone in Judge Dredd .... and awesome music back from the days when I loved all the classics
Apotheosis - O Fortuna
http://www.youtube.com/watch?v=WJ76EOVpQMM
Praga Khan - Injected with a Poison
Nightcrawlers (where my nickname emanates from) - Push the Feeling On
I could go on for hours of classic from the early/mid 1990's rave days :) .... damn I must be old :D
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
