Hey guys
The turbo is only 2000,kms old, selling to go to a much larger turbo. Still covered under 1 year warranty!
Ive got a Hypergear atr43 (g3 profile) with all lines to make it a direct upgrade for a rb25
comes with stainless 3" dump pipe so it will bolt straight up to your current R33/r32 cat
this is a complete bolt up kit and goes onto your standard exhaust manifold
should make 260rwkw on a rb20
details of the turbo are as follows
.70 front cover (huge)
.82 rear
internal gate
high pressure actuator
wastegate controller
3" V band clamp
This kit is currently on my car, i can take you for a spin in it
makes 300rwkw on 17 psi
hits full boost at 4K rpm on a stock rb25
very responsive, good daily driver turbo
located brisbane south
i'm asking 1000 bux for the lot
pm me for any details
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
