Im currently installing a 3540 on my 33 and was wondering if the feed/return water lines have to go in certain sides or can they go either way, ive got banjo barbs to use and if i follow the set up from the old turbo then the one off the block comes around to the exposed side of the turbo and there other one goes to the other side that you cant get at, would prefer to put the one from the block to the closest side and run the other one to the front.
Also i have a turbo beanie for it, have been hearing a lot of mixed thoughts about them lately, just wondering if i should run it or not?
It doesn't matter which way water flows through the turbo.
Your turbo beanie should be ok if it's a reputable brand, from what i've heard it's the quality of the stitching in some cheap brand beanies that's the issue with people saying the stitching burnt and the beanie just fell apart.
The good part: keeps heat inside the turbo and away from your engine bay etc.
The bad part: keeps heat inside the turbo!!!
If the underbonnet heat is not excessive without it and you have appropriate heat shielding then I would not run one.
Cheers,
SW
According to the turbo instructions the fitting of the water lines should facilitate water continuing to circulate through the turbo after the engine is turned off (brain fade - by means of the principle of hot water rising - can't think of the word for it at the moment) if that helps!
Convection?
It's ideal to set it up like that but it's not critical because once you turn the engine off the exhaust stops producing heat and everything starts cooling down anyway.
Convection?
Touch a housing 10mins after you've turned the car off - see how much it's cooled down ;)
There is still a rather large amount of residual heat.
Cooling down from "high load" type temps doesn't take long to get to 300, down from 600-700 degree or whatever.
But going from 300 to 200 takes quite a while longer
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
