My 32 4 door is up for sale. its just been thro regency for a full roadworthy and to check off the RB25det conversion and is now legal with that motor. Has full reports and emmissions reports done.
I dont have may pics as yet... something that i will organise is the next few days. But if you are actually interested by all means come and check it out in person.
Price $9500ono with 3 months rego WILL consider swaps with a S2 stagea + cash your way depending on the specs etc that im after. WONT consider swaps for anything else so dont pm with about your sick VP commo.
Car has the following
-Tien Tie rods
-Buzz spec Struts all round
-Rack spacers
-RB25det with RB20 ecu tuned for 12psi. Makes 210 rwkw.
-fresh respray done a year ago in Mazda metallic red (as seen on RX8) looks brilliant in the sun.
-handflared guards. will accept good sized wheels with no issues. used to run XD9's in 17X9.5 +15 all round
-straight as body and chassis rails
-HD clutch
-MINT gearbox
-Chassis has around 80,000 kms and engine about the same
-3 inch exhaust
-many bushes replaced
-18inch starcorps and a full set of stock 32 rims (no tyres)
-mp3 player
-brand new battery
-3 months rego
now the bad things
-missing some trim parts in the back
-pass side and centre air vents broken (common r32 issue)
-doorwindow switch has weird finish on it
Drives well and is very reliable. have done trips to mildura/horsham/sheperton several times with no issues.. quite economical on the open road. unique colour and just needs some decent wheels and you've got a real head turner.
heres a pic, as promised i will get more,
Contact me via PM, or sms/call 0412 938 933
https://www.sau.com.au/forums/topic/349695-clean-r32-4-door-with-rb25det/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
