Guys,
Got a diff here which had the LSD centre removed from it and standard centre put back in. Suits a non-ABS R33.
All in working condition, although one half shaft is missing.
Centre is good and used to give 2 black lines (not just one). Good to buy, shim, and swap out with your current diff.
This diff can be used in an ABS car, but your ABS wont work and youll need an ABS prop shaft.
$100ono
you can contact me via Pm
cheers Dean
https://www.sau.com.au/forums/topic/349762-r33-diff/
  • 4 weeks later...
all items need to go by the weekend.
standard diff - $50
r33 gtst s2 rear seats - $50
r33 gtst s2 steering wheel with air bag - $50
r33 gtst s2 standard inter cooler no piping - $50
r33 gtst s2 inlet manifold - $100
r33 gtst s2 standard ECU for a manual - $50
r33 gtst s2 standard afm pink label - $50
located north east suburbs of melbourne.
all prices are neg.
you can contact me by pm or call me on 0432886568
cheers Dean
Edited by Deanc
https://www.sau.com.au/forums/topic/349762-r33-diff/#findComment-5664784
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
