hi guys,
sorry if this has been covered to death but i couldnt find what i was looking for in the search.
i just recieved my new 910 pump and noticed on the outlet side it has that fitting for a banjo conection (ie, holes around the side) and a hole on the top at the end of the threaded bit. i just wanted to know what was the pourpose of this fitting and weather or not i could replace it with a normal fitting that would resemble the intake side as it seems abit disfuncional to have a banjo fitting coming off at 90 degrees if im going to mount it in tank. i can see a little spring in the side holes which had me wondering if it was a check valve aswell???
thanks.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/
Nah i wouldnt replace it with a hose barb or anything, its a sorta one way valve thing, top stop fuel running backwards through the pump I guess.
I just used a banjo, cap nut, and a loop of In-tank hose from the banjo to the top of the bracket. Double hose-clamped it at both ends.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-699774
cool thanks, i thaught it surved a higher purpose. I was abit confused cause ive seen some photos in other posts where it seems like the outlet hose just goes straight up (no banjo).
Does the cap nut block off the hole at the top??(sorry just not to familiar with the banjo).
does anyone have a pick of this setup?
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-699795
The banjo fitting isn't necessary. With my 044 I couldn't find one that fit the ball bearing valve on the top of the pump. Spoke to a few people, the consensus was that it is to stop fuel running back down into the tank, but that it's not necessary. So I took it off and fitted a standard barb connector and it's never had a problem. Not even extended cranking after sitting idle for 2 weeks. The 044 primes so fast that the valve isn't needed.
Since you already got the banjo fitting that's good, but if anyone else out there can't find one then you don't need it.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-701097
Nothing that I know of. The only thing I can think of is that the valve would keep the fuel line under pressure even when off. I don't think it would all drain back down into the tank, because that would mean air would have to get in the line. Where would the air come from? The regulator should stop any air coming back through the return line. Get a straw full of liquid and hold it by the top covering the end to see what I mean.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-701389
that makes sense, i know the supply side of the pump (standard)holds pressure though cause when i disconected it just after that fuel tank cap once it spray out fuel everywhere.
i guess if i cant find the banjo ill get a barb fitting. do these pumps always come supplied with the banjo fitting?
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-701408
The pumps don't come with a banjo fitting, that's why I had to remove the valve. Sorry I misread your post, I thought you already had a banjo fitting for it :D
I went to Pirtek and Earl's who both have a bazillion connectors, and neither had a banjo connector of the right size. I spoke with the guy at Earl's and he said it shouldn't be necessary, and a couple of other people have told me likewise since. I've still got the valve though, in case someone comes up with a good reason for putting it back on and gives me a banjo connector to suit. But until then it stays in my spare parts box.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-701448
sorry i meant do they alway come with the valve, I wonder weather the valve is just there as an option to fit a porticular make of car. it ticks me off how they supply us with this wiz bang valve thats impossible to get fittings for.
oh well seein as ur in syd and didnt find the fitting it looks like ill just have to remove the valve and get a normal fitting for it,
gives me a bit more confidence doin it this way knowing its already worked for you.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-701480
You won't blow the tank even with a short. For a start, there is no air in the fuel, and you need air to have a fire/explosion. Secondly, even in the air above the fuel (if the fuel level drops below the pump) there are too many fuel vapours for it to ignite (ie, too rich a mixture). And thirdly, consider this - the fuel pump runs off 12v. The spark will be 12v. Your ignition system runs off 10's of thousands of volts, and even then sometimes it fails to ignite even when vapourised and at the correct mixture (think cold cranking on cold winter's morning).
Put it short (no pun intended) you're not going to blow up even if you botch the wiring :rolleyes:
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-704418
So you're telling me that all these movies with cars that explode with the lightest taps are fake???
Say my mobile rings in my pants pocket when I'm filling up at the servo? My balls won't spontaneously explode like the sign says?
btw. does anyone have a list of all parts you need to get from Earls to installl an 044?
T.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-704425
My 044 has exposed wires. There'd be no way to really seal them on an internal pump I don't think, fuel has a very low surface tension and it gets through everything easier than even water would. If the circuit is good then there's nothing for it to spark against anyway.
If you really want to test it, get a car battery and a small amount of petrol, and try sparking it with wires to make the fuel ignite. Do it under the most favourable conditions you can think of. See how hard it is to do, then imagine it being 100 times harder in your isolated fuel tank where you couldn't even breathe the air above the fuel due to the vapours.
It's just not going to happen. I've read about stories where people accidentally set fire to their petrol tanks through the inlet (usually through static grounding of the pump), and there's only a tiny flame despite it being above 50 litres+ of fuel. The only place it burns is where it's getting enough oxygen from, which is the inlet. So you can stop it just by putting the petrol cap back on.
Btw Tony, I saw a promo thingie on the History channel today about engineering's greatest failures. They had a bit where they showed a Pinto getting rammed from behind and exploding. I'm pretty sure that the main reason Hollywood picked up on the "crash -> explode" car phenomenon is entirely due to that great piece of American engineering. What I want to find out is where they picked up on the "crash head-on, then immediately vault into the air doing a torsional twist in a graceful arc before crashing back onto the ground" thing. Various movies/series spring to mind that do this, but the one that sticks in my head the most is the A-Team series from the early 80's. I don't think an episode went by where that didn't happen at least once.
Sorry, I'm just ranting. It's late and I need to go to sleep.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-704525
the only thing that is covering the terminals on a factory pump (r32 gtst) is a little rubber cover for the positive lead terminal, the negative terminal is exposed bare. So if out of the factory they werent worried about sealing these connections then why would we. As long as the wires are crimped properly and nut screwed on tight, it shud be kool.
i pulled the banjo fitting supplied with the 910 off and didnt use it.
https://www.sau.com.au/forums/topic/34991-bosch-fuel-pump/#findComment-704856
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
