Is 7mm spacers safe for V36 rear wheels? Mine's not Hubcentric but i figured since its only 7mm then it should be fine. The wheel shop guy said so as well as long as i changed to a little longer studs with it. :whistling:
Did research on it online but can never get a straight answer..some will say its safe some will swear it'll kill you...:rant:. Hoping people with V35 & V36 could offer some advice..:D
I would stay away from any spacer that isn't hubcentric, it's just too much load for the wheel studs.
If you must use spacers, any decent machinist will be able to turn up a set for around $100- $120. Also, are they those stupid diecast multifit alloy things? If so, throw them far away, no good can come of it.
When they fracture (and they will), you will break a bunch of wheel studs, and destroy a wheel/your car.
Cheers, Dale
if you must run spacers, just get hubcentric bolt on ones. Don't risk flimsy "universal fit" floating spacers on the off-chance that they may work fine, coz the consequences otherwise can be quite devastating not to mention illegal.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
