I did some recearch when looking for my Skyline.
Called my uncle who knows a bloke in tamworth who sells them at a dealership. Asked if there is anything too look out for. He said Skylines are quite sound cars with no major problem to look out for... Basicially stay away from heavely modded 1's that u think have been thrashed or drifted on dirt tracks ect.
Bit of a quick checklist
rust
compliance date
reason for selling
has it got service record in aus
is the body straight
any crash history
tyre condition
scrtches on paintwork
seat ware
proof that km are genuin
weel shaking
tampering with dash skrews(puting back km's)
km numbers arnt alined
air bubbles in water
stained dip stick
put your hand over the muffler see if it stalls ( back pressure )
power steering leeks highpressure leeks from the steering box
windscreen chips
smooth gearbox change
wine noise in geerbox
shoks push down if they bounce they r stuffed
weel alighnment
normal oil pressure
Hears a more detailed checklist:
Examine in daytime
Examine in clear weather
Check for nicks and scratches
Check for thin, worn paint
Check for big defects (costly) and not minor repairs
General look around the outside of the car.
Examine both sides of the car from a distance (both front and back).
Look for ripples, waves, poorly fitted panels and mismatched colors.
Look for dents or rust around the bottom of the doors and fenders.
Check for bubbles along molding or chrome (indicates rust underneath).
Look under the vehicle for rust
Check for welding spots on the frame (serious accident or repairs).
Open and close the doors, hood, trunk or hatchback.
Stand back approximately 10 to 15 feet from the car and see if the car is level.
Check the shocks by pushing down on each corner of the car and letting go.
Check the tires (sidewall cracks, uneven tire wear, brake fluid leakage)
Look under the car for:
oil spots, or
transmission fluid or
power steering fluid or
shock absorber fluid.
Open the hood and check belts and hoses for cracks or wear.
Radiator coolant should be a clean, greenish (or blue or yellow) color.
Pull out the oil dipstick. Oil should not be gummy or grayish or smell burnt.
Check automatic transmission fluid, should be clear and reddish.
Check the fluid level in the master cylinder as well.
Look inside the trunk for an inflated spare tire, a jack and a lug wrench.
Back
Interior Checklist
Check the mileage
Compare mileage on service stickers (door jamb/under hood) to the odometer reading.
Check the condition of the seats, belts and carpeting.
Check the windows to see if they open and close easily.
Check the brake, accelerator and clutch -- should work smoothly, no strange noises.
Check all exterior lights and flashers on the car
Start the engine and check the warning lights and gauges
Make certain that the air conditioning blows very cold air.
Check the glove box for the owner's manual.
Do not be afraid to take up the salespersons' time.
Stay in control
Do not let anyone talk you into buying a vehicle you do not want.
Back
Test Drive Checklist
Drive the car on hills, highways and in stop-and-go traffic.
Start the engine and press down on the brake.
Listen for noises which could indicate engine problems.
Put the car in neutral and rev the engine. Check for smoke from rear exhaust.
Punch the gas pedal. Does engine respond without hesitation then return to normal?
Check the lights on the control panels--be sure they all work.
Does automatic transmission shift smoothly?
Manual transmission should shift smoothly between gears without grinding.
Clutch should engage and disengage smoothly without grabbing
Drive in reverse
Does car pull or vibrate when driving on a flat, smooth road?
Do the brakes grab evenly and does the car slow down in a straight line?
Drive at 35 miles per hour and listen for any unusual noises.
Accelerate to 45 miles per hour, does the front end shake or vibrate?
Drive quickly over a rough road and listen for any loud squeaks or rattles.
Does the car bounce or bang over small bumps?
Check the temperature gauge to see if it shows a high reading
Accelerate hard on an empty road, does the car respond immediately?
Try it again.
Accelerate on a hill, does the car respond immediately?
Cut off the engine. Then restart the engine -- does it restart easily?
Check for leaks under the hood and beneath the car.
Check the tailpipe. Are there any black, sooty oil deposits?
Does the odometer mileage seem to match the physical condition of the car?
Check odometer for scratches, misaligned digits, digits that stick.
Or get a mechanical inspection if u got the cash.
https://www.sau.com.au/forums/topic/34997-ecr33-hr33/#findComment-700270
put your hand over the muffler see if it stalls ( back pressure)
This may not be the best idea mate :( I suggest you give this item a miss :Oops:
One thing that's very important, more so on GTRs than GTS-ts is check for rebirthing.
The BLUE Nissan Build Plate should have the details PRINTED on it... i.e. If you run your fingers over the details printed on it, it should be smooth. IT SHOULD NOT BE ENGRAVED... If it's engraved, it has a fake Nissan Build Plate with a fake Chassis Number. These are forged and put on stolen cars with a new and legitimate chassis number.
This BLUE Nissan Build Plate *should* also have two white plastic rivet-like fasteners holding it on... If they're missing, ask yourself why. The Build plate should NEVER be removed, unless perhaps for a full respray including engine bay...
https://www.sau.com.au/forums/topic/34997-ecr33-hr33/#findComment-700730
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
