Hey guys, not sure if this should be in this thread of the whole car forum but im parting ways with my 1989 r32 gts-t with s2 rb25det. The rb25det conversion was done approx 2 years ago, and was a full conversion inc gearbox.
I have owned the car for the past 6 years after importing it myself and having graduated uni im about to move for work so its time to part ways. Car would be perfect for either an enthusiast willing to put some work into it or alternatively as a running wreck. The car is still registered until June and running so you are welcome to come out and see the engine/gearbox in running condition. The primary reason for selling as a wreck rather than registered is that im rather busy at the moment so I do not have the time/energy to get the car a road worthy however im comfortable if the buyer wishes to do this themselves while the car is still registered to save hassle.
Notable specs of the car are:
185,500 k's (64,000 on the series 2 rb25det)
rb25 gearbox and running gear (when the conversion was done, all mounts was custom fabricated so this would suit either an r32 with the mounts provided or an r33 with your own mounts)
Recently replaced high flow radiator (purchased from one of the SAU group buys)
Recently replaced bosch fuel pump
Apexi turbo timer
HKS boost gauge
Momo steering wheel
17" rims
Things that require work is the body. There is a dint about the size of a 50c peice in the rear near the tail lights, along with a dint in the drivers side door where a trolley has hit the car. The car could generally use a paint job also and a few of the seals are starting to wear/peal due to age. There is also a dint in the passenger side front quarter however replacement guards will be provided so that shouldnt be an issue.
There is honestly alot of other extra's (skirts, stainless dump pipe, high flow exhaust eg), i'm currently in a flood effected area of South East Qld (although the car is safe!) and as soon as the flood water resides I will go out and photograph everything.
Asking $7,000 as an unregistered rolling wreck but as I said im happy to help the buyer out if they wish to get a roadworthy to keep the car registered. As I also mentioned im not thrilled on separating items of the car at this stage but if a few different guys are interested in taking different parts (i.e someone wants shell, another engine and gearbox) im happy enough to do that.
Contact Matt on 0409055258
Edited by Tizzle
https://www.sau.com.au/forums/topic/350118-wrecking-r32-gts-t-with-s2-rb25det/
  • 3 weeks later...
  • 3 months later...
Hey guys, FINALLY have some pictures up. I've highlighted the notable damage to the body being the front left guard and the rear right corner. I have a set of fibreglass vented front guards that I paid $450 for about a year ago that I am happy to include in the sale to be used to replace the front guards.
Any other questions either pm or for a faster reply text on 0409 055 258
  • 3 weeks later...
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
