Hey guys the wife and I live in sa are looking at getting a c34 stag somethime in the next few weeks and are just curious on a few things. The first is major service, is this done at 100k? And what would it set me back $$ plus who would be a trustworthy mechanic too take it too when I need something fixed? I only ask because there is a free for sale getting close too the 100k mark.
Also a reliability question, at the moment we plan not too mod it, however I may decide to do some little things, fmc, zorst and maybe some airflow, nothing stupid and plan not too boost it.
Are they a reliable car with these simple mods?
And finally is there any common falts I should look for on inspection?
Thanks,
Fires
https://www.sau.com.au/forums/topic/350463-new-guy/
Absolutely awesome cars, mine is pretty heavily modified but the engine is still unopened. I also driving it HARD and it loves it, begs for more!
The only issue I have is front CV's have started clicking but the front axles are the same as all the GTRs, have a set coming in through Maytech very soon.
P.S. make sure you go a series 2!
Edited by bubba
https://www.sau.com.au/forums/topic/350463-new-guy/#findComment-5628226
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
