People need to be able to edit their original posts in the for sale section.
I know it sounds a bit crazy, but I think it'd be easier if prospective buyers only had to read the seller's original post. Rather than having to read the original post then scour the rest of the thread to see which items have been sold or had their prices changed.
Thank you for considering this wacky and unconventional suggestion.
Sincerely,
Common sense
https://www.sau.com.au/forums/topic/350523-news-flash/
Scammers tend to edit their first post after having ripped people of hudreds or thousands of dollars, making it impossible to be of any assistance afterwards.
As a side benefit, it also enforces sellers to adhere to well thought out, logical sale posts rather than a half arsed effort that is of no use to anyone.
If this seems disadvantageous to you, then by all means create a second "placeholder post" for future updates.
Thanks for your suggestion, but this feature is the result of operating under various arrangements for over 6 years. This is the optimal result, deal w/ it.
Kind regards,
Reality.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5626987
Ahh, good point. People can't scam if they can't edit.
Wait, no..
How familiar are you with MySQL and MySQL dumps?
If a copper contacted you about some poor schmo who spent $5k on a non-existent turbo kit only to find that the original thread was nowhere to be found, reckon you'd be able to trawl through 100+GB of mysql dump files to find the original thread and post?
Oh wait, but what if the thread was made and deleted between backups?! What will we do now???
I see you put a lot of thought into your suggestion, but you could have also put the same amount of thought into PM'ing a moderator of the for sale section to request they change your thread.
We're not exactly new to all of this. :)
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627068
wow triple threat smackdown.
lol Dvus its been discussed heaps and its the most manageable solution. PM a mod or admin if you need massive changes, or in future post a placeholder ppost after the first post for updates.
triple threat. so hot right now.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627076
What's triple threat?
Speaking of SAU's role in hunting down forum scammers, I read this somewhere;
"Skylines Australia takes no responsibility for transactions that occur as a result of this forum. CAVEAT EMPTOR - BUYER BEWARE!!!"
Anyways, I had a feeling I'd end up getting into a cockfight by posting feedback in the feedback section. Jokes aside though, I just wanted to put it out there as a matter of principle, not because it's a big issue for me. Thank you for your explanations.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627235
I suppose your local paper should be responsible for every item they advertise in the classifieds too.
No we're not responsible. However, we do like to take time out of our normal schedule to help those who have met with irresponsible sellers.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627244
Well it's been put out there in 10 pages of the thread that already covers this
http://www.skylinesaustralia.com/forums/topic/341192-cant-edit-posts/
Thanks.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627323
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
