Just wondering about M35 ARX's Standard stereo equipment.
Do they all come with Bose speakers? Or are there cheaper factory options?
I know the sub in the spare wheel seems to be a pretty rare option but not sure about the speakers, head unit etc.
Reason, being is that I'm looking at one that is currently 'on the boat' from Japan so they don't have any stereo info yet. ... Comparing this to one that I have looked at that does have the Bose (The sound is great!)
Not really a huge deal to me but interested just the same.
Edit. OK, after some more searching, I found that there is also a Clarion deck for ARX, so I suppose they would have lesser quality speakers?
Do they still sound OK?
Edited by jidge
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/
i have the base system.. speakers are panasonic.. head unit is clarion. All m35 and V35 head units are clarion units.. even the ones with Bose imprinted on em. I had to get my sisters one fixed which is bose, and its a clarion, found out by googleing the serial.
I think they sound good for a stock system. but since I pulled the DVD thing out the screen doesnt work.. looking for a double din one without the screen. i wanna put my system in :)
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5632658
aaron,
shoot me a PM I can probably help.
one thing to note on teh ARX as well. the 6cd does tend to destroy itself AND if the unit dies it takes the A/C with it. bear that in mind.
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5636339
Cheers Chris.
I am pretty much set on an ARX so I guess i will have to cross that bridge when i come to it.
Are they difficult to repair/replace?
Can you just disconnect them when they fail to avoid it taking out the air con.. Or does that take out the whole head unit.
PS. Had another look/listen to the stereo in an ARX I was looking at and I could not see Bose written anywhere, so I guess it was the standard system. It sounded pretty good to me.
aaron,
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5637728
up to 2007 I could fix them. now parts are becoming scarce for them. when the unit dies IT WILL TAKE THE A/C with it. there is no getting around this without spending money on new panelwork and controls.
the dead unit syndrome I can fix the F0 and F3 errors will write the unit off. if it happens that you get a car like this have a spare $1k handy.
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5637737
along that topic, my 6 stack in my RX is dead, but AC is ok still, but just started to die from time to time, is it possible to save the AC now by disconnecting stacker? or does it need to be repaired?
really dont want to have to spend another 1k on it ATM
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5638206
if its stating to fail - pull it out and send it up to me. I'll repair it and send it back. once it fails you have NO control over the A/C at all. it will lock on whatever you last had it on OR 24 deg.
stacker is not the cause of the dead unit sydrome..
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5638265
  • 1 month later...
Another question along these lines....
If the stereo fails in an ARX, is it possible to just replace the double DIN with an aftermarket double DIN? Or even if it hasn't failed.
There would be some cutting of the dash etc. But if it was done properly would it be possible?
Cheers
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708515
it will look like shit if you cut it
get a proper double din. but AFAIK they are only available in black. however in the US the beige interior was popular so might have them in that light grey that the RX and ARX uses
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708536
OK. So no cutting, that probably would be shit.
But not sure exactly what yo mean about getting a proper double din??
Cheers
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708579
Yup it's all one unit. Had it out the other day. And the cassette cd and aircon are one. You can separate I think but hell of alot work. And pain to do.
Edited by whitestag
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708853
Just forget the CD aspect of the stereo and put in a Spec dock and use your Ipod or Iphone. Then you will have music / video's and navigation all from your iphone. If you have jailbroken your Iphone you can even output the display of your ipone to your monitor.
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708913
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
