Just thought someone posted on here a while back about Dirt circuit racing so i was wondering if anyone had heard about it or knew of who it was that made the tread? I had a guy and his son come in to work and said they were buiding a car so I looked into it a lil and it looks like some fun. If anyone knows anything or someone I could chat with about it, please let me know.
-Nath
https://www.sau.com.au/forums/topic/350992-dirt-track-circuit-racing/
-Nath
yep know all about it mate ive been helping build the track the last 12 months what do ya want to know ? pm me ya ph number i can fill ya in cheers dean
From what ive heard is that the NA r33 gts4 with the AWD gets the power down a lot easier on the dirt. Where the big powered cars just will spin. Ive been offered a drive to check this sport out. Sounds like fun. I just have to make time for a look.
Here's a couple of videos from last season at Truro & district raceway. The in car footage is from an xf falcon.
It's going to be a big 2011 season with 8 race meetings in total, starting in April and finishing in November, this includes a grand opening in May. There are alot of new cars being built ready for this season, including a couple of gtr's (converted to RWD).
Edited by GROWLY CUSTOM CNC
dirt circuit family membership is about 30 bucks a yr and anyone in the family can use the car . so on the day the same car could be used in juniors race and if ya mrs wants a race she can use it in the ladies race and you can drive it in whatever class you built it for .
ive seen the same cars run almost non stop all day lol .cost 10 bucks on the day too race ...all ya need is a crash helmet a pair of king gee overalls and leather boots as a minimun to go racing .
no cams lincense or huge entry fee's good family fun
cheapest motor sport around . i myself have a full space frame car with a quickchange sprintcar diff and coilovers all round with a ve commy body and 308 and owes my less than the average rb motor rebuild cost lol .
just make sure the roll cage in that 808 meets our specs or you could run into strife
cheers dean
Minibats,
I'll pm you a link to the pdf version of the rule book / build specs. You will need a hard copy to race ($10) but we are waiting for another batch of books.
Just for interest sake here is an approx break down of the costs for my build (street stock). I have a lot of bits and pieces from previous cars so it will actually cost approx $750- $800 with the extra parts. But starting from scratch this is what you would be up for.
XF falcon (carby version) $150
Rollcage steel $350
protective body bar work $150
second hand race seat $50
new g force 5 point harness $100
fire extinguisher $25
second hand jerry can fuel tank $20
gearbox, clutch for manual conversion (second hand) $50
front window mesh $20
side window net (second hand ) $25
Cheap gauge set $30
sheet metal for covering holes (lights, fire wall etc) $50
mud flaps $20
Total $1040
Extra parts if budget permits (second hand)
350cfm holley $100
extractors $50
cam shaft $50
valve springs (new) $100
* also need a second set of spare tyres.
I think Dean would agree with me, the secret to building a cheap dirtcircuit car is not rushing out and buying all the parts at once, but take you time sourcing cheap parts and you could save your self 50% of the build cost. Also getting together with a mate and sharing the car is a great way to save on build, maintainance & traveling costs. The racing is set up so there is 8 races per class during a meeting but all drivers can only compete in 4, so sharing a car does not mean you will miss out on any races.
Cheers Matt
plenty of cheap r31 skylines out there smash out the windows chuck in a cage go racing
good cheap fun and learning car control on dirt is an absolute pleasure
and does get a bit argy bargy at times but that is half of the fun
heres a short vid of mine crap quality but na rb25
sounds pretty good getting the tits thrashed out of it
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
