Hi,
Looking for some help with cams... I've just bolted up a GT3076 A/R 0.6 with internal gate to my RB25 series 1 and I have a pair of Tomei Poncams 256 degree 8.5mm lift I would like to drop in. I'm not looking to get any real power gains from them, but just to move the powerband round, for more response and and earlier spool up, would these cams be adequate for the job? The cams came with the option VCT retained, what is this about and is there any tutorials or DIY's on instalment of these cams?
The job itself is fairly straight forward if you have good mechanical skills. Download the RB25 engine manual and there is a section that covers cam swaps. Just follow that.
I see your located in Townsville.. Any good tuners you could recommend?
I fit Tomei Type-B's to my 26 a little while ago.
Some things you might like to know...despite what others might say, I got the motor to TDC and zip tied the cam gears to the belt, the gears are a little tricky to get back on doing it this way when reassembling but its def do-able. Removing and reinstalling the cams is easy enough, just unbolt the caps in the factory sequence and do the same when refitting, be very careful when retorqueing the cam cap bolts and use a small 1/4 Drive inch/lb torque wrench or similar, they are piddly little 6mm bolts and are very easy to over torque and snap!...You will likely need to replace the cam seals, its worth doing if they havent been done even if you get them off without damaging them at all. Use sufficient assembly lube on the cam lobes, lifters etc.
If youre not at all mechanically minded, I wouldnt take this on yourself, you'll need a timing light etc once youre done to check timing. Good luck.
Edited by NSNPWR
  • Like 1
Yeah I would recomend winding it back abit from top dead centre that way theres no chance of the valves hitting cylinder 1 or 6 as they can be abit tricky to keep straight when putting the first few cam brackets on. Doing the springs would be a good idea to save you from having to open it up again.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
