What sort of idiot would smash and grab your $100 boost gauge? I think you'd be more than likely have a thief smash and rifle through your console for spare change, and any CD's lying around. I know of many people that have had that happen, but I've never heard of a thief targetting an A-pillar gauge. The friends I know that have had this happen didn't even have any loose change or CD's visible through the window, the thief just took a chance and found them.
The only problem with the instrument cluster mount is it can interfere with the reading of the other gauges. When I got my car my gauge was there, and it blocked off the tacho from around 5000rpm and up. So I removed it and later had it mounted on the A-pillar. If you can do it carefully enough though and have a small bracket, it won't block your view of the gauges. My mounting bracket wouldn't permit this though which is why I moved it to the A-pillar.
Anyway, if a thief can see a boost gauge mounted on the A-pillar he can see it on your dash, so if you're worried about a thief stealing it, then best don't put it in your car at all.
As for legality, I'm pretty sure you can be defected for having it on the A-pillar. But I've gone through several RBT's and no cop has even commented on mine, so in Sydney at least it tends to be something they generally ignore. But I'm sure that if I pissed a cop off they would quickly defect it. In that case though it could a distraction from something more of a pain in the arse to fix - like being too low or something. If they just want to look for one thing to quickly defect you, the A-pillar gauge is easily fixed and preferable to almost any other defect IMO.
Well its in and installed now, it turns out that routing the tubing is actually pretty easy... heres how i did it.
For an S1 R33
1. Remove the dash panel below the steering wheel.
2. Remove the lining that runs up the a pillar then along the top of the drivers door.
3. This should reveal a gap at the base of the a pillar.... run your tubing down this to get it under the dash.
4. take the end of the tubing and tread it through the existing hole in the firewall (located just behind the right hand edge of where the stereo sits, maybe a little higher)
5. this should exit just to the right of the intake manifold if your looking at the engine from the front.
6. Now comes the choice of lines to tap. The closest line is the line that runs to the stock boost sensor (little black box located in the back left corner of the engine bay when viewed from the front). This line leaves from the back of the intake manifold and runs straight left. This is nice and convenient, But if like me you have an apexi mech boost gauge, the supplied T peice is too big for this hose, so instead use the hose from the front of the manifold, its thicker and just like the one from the back... it will gauge the intake manifold pressure. For this i ran under the air intake and other leads to the front.
7. Cut the desired hose where u wish to join and insert your T peice.
8. Attach your gauge hose to your T peice.
9. use cable ties or similar to tighten the join on the T peice
10. find and attach gauge wires to power if applicable (i'm not going to tell you which one, just find on with power when the lights are on but non when they're not (lighter adapter for instance).
11. Depending on the length these wires can either follow tyhe tubing or instead shortcut down the side of the dash and under the panel removed earlier, dont worry when we put the panel back on it will be protected/hidden.
12. Next replace the 2 removed panels (the a pillar panel and the footwell panel
13. connect your gauge to your hose and wiring and mount as needed....
All done with no hole drilling...
did i miss anything?
What was it over the pits for in the first place? Were these compliance engineers? In other words; where can I go to get a cert if I put a gauge on?
at the licenceing center, fill out an modification form, i got permits for piller guages a have two, air pod, upgraded intercooler and pipe work, basicly anthing thats not stock. iv been pulled over, or stuck i a car park on a crusie and these permits have saved my ass heaps.
o and the permit for the conversion, i never had to see any enginers, no body work had to be cut. This is all done just at the general licenceing center.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
