Not a game Microsoft will allow to be released on console. But if you set your Kinect up on your Windows 7 PC then Clutch can finally feel some chick's boobs.
http://www.cnet.com.au/kinect-sex-game-in-works-339308051.htm
https://www.sau.com.au/forums/topic/351639-kinect-goes-sexytime/
http://www.cnet.com....s-339308051.htm
when did you buy this game craig?
does your mum bother you when teh fapping begins?
Edited by Clutch
Are you positively annoyed friend?
games not out yet BTW.. or did they give you a game testers copy? LOL
i don't live with my mum unlike others, but the missus doesnt always put out on demand ;)
PS. only works on PC so not much point when you can just watch porn and have both hands free :ph34r:
i aint even mad
you cant re use my dig and use it against me...
i don't live with my mum i live in the bungalow out back, but the mr doesnt always put out on demand ;)
FYP
story of your life
Edited by Clutch
  • 3 weeks later...
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
