Due to unforseen circumstances i have to sell my latest project
track only R32 gtr but was originally brought into Aust with JMS who organised the shipping/import approval for a customer
it has race/rally import approval so if you desired you'd be able to get it race/rally rego'd
located in Adelaide
R32 gtr
5 speed manual
excedy clutch
N1 turbos
Apexi filters
clear heat shield
thick sway bars front/rear
stripped interior
straight pipe style exhaust
CF bonnet
bride fixed back seat & rail (new / not fitted)
harness (new / not fitted)
sparco removable steering wheel boss kit (new / not fitted)
personal italian steering wheel (new / not fitted)
has all new gaskets on the inlet side of the manifold
will come with some stock rims, more than likely S14 rims (not gtr rims)
has a little rust around the rear drivers guard
currently in RWD mode due to the factory steering wheel being removed and the new one not being lined up 100%
Chasing $9,000 ONO may even throw in some genuine jap plates if its sold quickly
Adrian
SMS ONLY DUE TO LOOKING AFTER 2 KIDS - 0402 222 831
https://www.sau.com.au/forums/topic/351640-track-only-gtr-sa/
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
