1998 R34 GTT
90,xxxkms
Exterior
Bayside blue paintjob
Has a black bonnet because I got defected with the fibreglass bonnet(no longer have fibreglass bonnet)
Full bodykit
Factory HID's convertered to run h1 halogen globes as well for regency trips
Braided brake lines not yet installed
Engine
D34 Yellow top (still under 2 years warranty)
Front Mount Intercooler
3 inch exhaust
Drift Pod
Extreme HD Clutch
Interior
Viper 2 way alarm system
New red velo gp90 seat
Brand new Nismo gearnob
Brand new Nismo 300km 10k rev cluster
New genuine Nissan aluminium pedals which have not yet arrived
Bads
Paint not in the best condition
Interior could be better
Small dent on righthand fender
Bodykit needs tlc
AC works but need regas
Rotars have been recently machined and fitted with QFM hpx pads have reciept
I can be contacted on 0416942503. Am negotiable so throw me some offers. Will not answer to text or pm's if you are serious give me a call and we can talk. Will upload pics later.
Reason for sale want something different. Thinking about getting a bike or s2000 or cappa
https://www.sau.com.au/forums/topic/351762-r34-gtt-manual-adelaide/
hey man spoke to u a while ago bout swaps for an 09 fireblade.
Offer is still there lol
or would u be interested in swaps for a brand new kawasaki ninja 250r?
learner legal
was bought as a christmas gift
cheers man
0435183200
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
