For Sale: Defi Link BF (White Illumination) Set
Set Consists of:
1x Defi Control Unit 2 inc Power Loom & 2M Defi Meter Cable
1x Defi Link BF (White) Turbo (Boost) Meter inc Guage Cup, Sensor Set & Link Wire
1x Defi Link BF (White) Water Temp Meter inc Guage Cup, Sensor Set & Link Wire
1x Defi Link BF (White) Oil Pressure Meter inc Guage Cup, Sensor Set & Link Wire
1x Instruction Manual
(No Boxes as all have Been Discarded)
Not included are adaptors for Oil Press & Water Temp Sensors as they have been retained on my vehicle for future purposes.
All items are used but are in excellent condition. I Need say nothing more about these guages as we all know how accurate and essential they are for knowing & maintaining safe engine conditions and that Defi are a Very High Quality Japanese Product.
Rest Assurred that these are 100% Genuine Item and not the fake copies doing the rounds. Ive attached a few pics below of the Items
Price: $950 (With Free Express Post Shipping Australia Wide)
Contact: Please feel free to drop me a PM and ill reply at my earliest convenience as work has been pretty hectik lately.
Feel free to make a reasonable offer, also check out the stuff in my signature...
Edited by krayzie32
Sorry bud not interested in splitting them up...
Thanks to everyone else for offers for lot but they are all just abit shy of the magic number in my head...
First one to accept the counter offer takes em...
  • 3 weeks later...
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
