I have suspected my cas to be faulty for some time the last week especially when I start the car it's starts up spluttering with a few revs it would go away also car won't hit boost until warmed up fully I gave always had a pop man miss on idle which turned into miss to the point it has trouble idling .. Idles round 600 and rough as guys I am replacing the tps and cas today but wanna be sure they are the issues any help appreciated my car Is a daily so need it sorted thanks
https://www.sau.com.au/forums/topic/352556-is-my-cas-afm-or-tps-dead/
Changed cas and it is alot better but the miss is still there when it's cold and it still has idle problems it nealy stalls still would the tps be doing that ? I unplugged the afm while the car was going and it just stalled shoundn it keep running ? Ithought It would just have a fluctuating idle with it unplugged? Any body had this issue!
I'm starting to look at the worst case scenario here maybe I have blown a ring and might be down on compression in a cylinder I think that because when I first start it ( cold start ) the it's like it runs on 5 cyl :( and under light throttle the ( just easing the power on) the car is hesitant sluggish and surges real bad it's a pig to drive but as it gets to running temp it comes good except from flat spots which I think is timing Im gunna do a comp test tonight
600rpm is to low for your idle. You should change it to about 850rpm, or check your base idle anyway for starters.
Have you checked the timing since you installed the new CAS? It might be slightly out which is causing these issues.
Probably not AFM if theres such a noticable difference when you unplug it.. If you know someone with the same type AFM then you could try and borrow theres and see if it makes it any better just to rule it out
From the sounds of it, I'm Leaning towards it being a timing issue. Have a search on here to see how to check your timing
Ok I think my timing is all screwed I have flat spots all thru the revs till after 5g and then my car violently jerks back and forth backfires and is a right pig to drive 89 cal I have not got Access to light till tomorrow so will check then.....
God I hope it's timing I suspect maybe a collapsed ring when I cold start it starts up missing kinda Like when there is an injector not firing or a coilpack arcing out
Also when I first start it I need to pump the shit out of the gas and it never starts first go and when It does u have to leave it sit Idling with ABSOLUTLY no throttle
If I try to rev at all it just wants to die and miss to the point if stalling it :(
It was that bad today that when I tried pumping the gas on initial start it was drawing enough energy from the electrics that it was turning my greedy turbo timer of and on as I tried to pump the gas which is seriously not right this is REALLY MAKING ME WONDER WTF
Yeah standard ecu it had a tomie chipped ecu but took it out when my cas went because the aggressive timing map and dodgey cas made tha car detonate under load ....
I have suspected my timing to be out because the car is so hard to start in the morning or at first start I don't think I have dropped a ring now ;) I started the car this morn it was hesitant to stars still but it started and idled fine so I think the ecu has started to learn and correct some of the issues I am putting a light on it this Arvo I'll let you no ow I go thanks agajn
You can reset the ecu and i think it will slightly advance timing on first start then bring it down as it learns what the engine is doing. I suggest checking base timing then maybe reset your ecu as well. Might work a treat
Ive reset the ecu already when I put the new cas in ....
today when I drove it seemed to run a big better which will be the ecu learning as you said as for the flats spots no change as yet but I no it's timing because when my knock sensor lead fell off it felt the same then the timing was being retarded big time as for the light my mates light doesn't have the clip for the trigger wire so have to wait again
  • 5 months later...
Cam Angle Sensor: used to determine where TDC of each cylinder so the engine can inject fuel and power the spark plugs
Can also be Crank angle sensor getting the measurement from the crankshaft is some engines
In RB series engines it is the silver thing on the timing cover (exhaust side)
I tried unplugging my AFM on my r33 series 2 and starting the car, the car doesnt start at all!!! but when i plug in my AFM and start the car it works. But its got idle problems too. so faulty AFM???
i've got the lumpy start up unless i rev it a bit or let it die and 2nd crank around is always as it should be as if it never had the problem, ive always thought it was the hot wire where the AFM is and the switch board ontop just needs re soldering but have never gotten around to it even though i have rebuilt the engine ........... maybe tonight :)
Also if the AFM is faulty it can cause what looks to be lumpy timing just because the engine has no idea of the air volume.
Edited by central coast person
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
