This topic has been covered many times before.
My opinion - go for a high flow panel filter like a K&N. Though you'll only be looking at minimal power gains. To maximise bang for buck, you could run another pipe from the front bumper up to the airbox for extra cold air (together with the stock airbox intake funnel).
I think pod filters are a waste of time with or without a heat shield.
Cheers
I used the search button and found this thread! I also am thinking of removing air pods and goin for stock airbox. But dunno if my GReddy intake piping will line up with a stock air box.
Maybe a custom made one is the go! ? Can't imagine all that hot air is doin the intercooler any favors....
I agree,
I think after reading many threads & different methods the best set up is a dry panel filter with a custom cold air intake
system at the front bar...
This thread was purely intended to get as many people's outlooks on Pods Vs Panel set ups, so please throw in your 2c.
  • 3 weeks later...
If you go pod you have to build a heat shield, otherwise it will only sap power and promote detonation. They do make it sound better apparently though. The verdict, thread after thread, tends to be go with a decent panel filter, and cold air intake if you're hardcore :D
  • 1 month later...
  • 1 month later...
When i bought my 33 gtst it came with an uncovered pod. I was made aware of them soaking up heat so i made a shitty shield in an attempt to stop it, but dont think it helped much. I have never really cared either way, but after going in my other mates gtst with standard air box, the pod does give my car a much cooler induction sound. I honestly dont think there is too much in it if both are set up well, but there is a sound difference.
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/search.html
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM r31nismoid or pal and we can discuss it further.
Edited by Thelen
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
