hey guys just a bit confused
went to go take out the boost restrictor our of my mates r33 gtr to find out the boost solenoid/valve is t there, instead the two hoses are connected to eachother.
is this why he isn't runing 14psi/1 bar ??
hits full boost around 7psi
if anyone can help me source one would be gratefull
cheers
tilla
https://www.sau.com.au/forums/topic/352801-r33-gtr-no-boost-solenoid/
If the 2 solenoid lines were simply capped off and not joined together what boost pressure would the r33 gtr get, and what would be controlling the upper boost level. Thanks
Edited by thatlbeme
No that's not correct. If the STD lines are blocked it will run low boost. The solenoid opens to add a small bleed/vac to the wastegate pressure line. Closing the lines just stops the extra 2psi. You will find the valve state is normally closed. When installing an aftermarket controller new lines and routing is required to control boost over the entire range, rather than just 2psi
it will run 0.9 to 1 bar with the restrictor removed and the standard boost solenoid fitted
well i have had it setup 2 different ways
the old setup:
at the very back corner of the plenum theres a vac line going into it, that was pulled off, extended and then connected to the "actuator" port on my boost solenoid
the nipple that his hose used to go to on the bottom of my plenum was my pressure source
the new setup
B4stll.jpg\
2 equal length vac hoses going to the actuators
T'd together at the profec boost solenoid
I drilled into the bottom of the twin turbo pipe, installed a nipple and got my boost source from there
i changed from old setup to the new setup because it wasnt holding boost very well and boost curve was falling over.. 1.2bar down to 1bar, even at 1bar it was quite shakey in terms of boost control, it wasnt solid at all.
Boost control was much better with the stock boost solenoid, it would come up to 1bar and hold it there like a rock, but the only problem with it was that i couldnt go over 1bar
My tune is booked in for monday, im hoping this new setup will hold boost alot better than last time.
Edited by snozzle
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
