Don't go soft on me now!
You know deep down you want the air jacks.
I fkn do.... Call me when she is ready... I don't want the divorce that comes with it!
Seems like every visit introduces something new lol just a cage this was suppose to be :O
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 5 weeks later...
Car is coming along good... just too many additions along the way,
which has held up things.... box was a big thing, thats now in ...
waiting for wire guy to put haltech smartwire (PDM) in
http://www.haltech.com/get-smart-with-smartwire/
and redoing all the lines and clamps and pipes in engine bay.... hoping a few weeks ;)
