Hey guys any help would be legend
Iv got a project 32 gtst rb20det which is basicly finished
Took it for a run the other day was running amazing ! no lag somehow (has fmic stock turb) boost was creeping even tho no boost controler(has to be boost leak?)
Then the next day took it out unlimited boost prety much wtf! yes i checked all the lines evrithin seems to be sweet and tight c;lamps on EVRITHIN (thort actuator line came off but didnt)
But the thing is it was gutless on boost? and unlimited over nyt? has waste spark setup also .
How the hell does it go from perfect to unlimited and gutless on boost ? feels like its hesitant
Any opinions ?
https://www.sau.com.au/forums/topic/353141-rb20det-boost-problem/
unlimited boost means there is no pressure signal getting to the wastegate actuator. that means either split hose (can be sometimes hard to see), hose come off (should be easy to see) or the system is not hooked up correctly. you need to take another look at the boost control piping or get someone else who really knows how basic boost control works to check it for you.
Iv got a project 32 gtst rb20det which is basically finished
Took it for a run the other day was running amazing ! no lag somehow (has fmic stock turbo) boost was creeping even tho no boost controler(has to be boost leak?)
Then the next day took it out unlimited boost pretty much wtf! yes i checked all the lines evrithin seems to be sweet and tight c;lamps on EVRITHIN (thort actuator line came off but didnt)
But the thing is it was gutless on boost? and unlimited over night? has waste spark setup also .
Any opinions ?
This sites fkn LEGIT
Cheers guys yeah i think ur right guna check out the hoses for splits its gta be it. the dump pipe isnt split so gates fine (i think lol will check anyway)
f**k i bet itd be real lean lol
Good definition on the unlimited boost ! f**k u both have gtrz!!!!!!! f**k take me for a blat lol
Good Kunts!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
