Hey guys,
My stagea is 4WD turned RWD, Previous owner had the front driveshaft removed I believe.
I'm thinking about fitting wheels which are:
18*8.5 +22 on the front and 18*9.5 +35 on rears. 225/35 on fronts and 245/40 on rears
Will this be fine to run considering I'm RWD?
Thank you.
Edited by gersfan
https://www.sau.com.au/forums/topic/353381-stagea-staggered-fitment/
Hi Rohan,
mate as long as rolling dia are same,should be sweet,
& as you may have read no need to pull front shaft,
Bubba is running RWD at moment with shaft in,
Good luck with small sidewall on WA`S poor roads,
how is he doing this? there is NO way you can safely run in rwd without pulling the shaft!
Bullshit. I've been running mostly in RWD since a couple of weeks before Powercruise. I have posted this up time and time again, if you refuse to believe, that's your problem but don't scaremonger.
Rohan, you want to run something like 225/40 and 245/35 to try keep the rolling diameter the same.. if you know what tyres you will be using, do a bit of research and match up some front and rears.
e.g. I run Federal 595's, if I was going to stagger I would go (depending on rim width) 255/35ZR18 90W 633mm OD and 225/40ZR18 88W 635mm OD
I think ATTESA can handle up to 5% difference before it flips out.
http://www.federaltyres.com.au/tyres/high-performance/595
18"
215/35ZR18 84W RF 606 7.0- 8.5 500
225/35ZR18 83W 613 7.5- 9.0 487
255/35ZR18 90W 633 8.5-10.0 600
265/35ZR18 93W 641 9.0-10.5 650
215/40ZR18 85W 629 7.0- 8.5 515
225/40ZR18 88W 635 7.5- 9.0 550
235/40ZR18 91W 643 8.0-9.5 615
245/40ZR18 93W 651 8.0- 9.5 650
225/45ZR18 91W 658 7.0- 8.5 615
245/45ZR18 96W 676 7.5-9.0 710
255/45ZR18 103Y XL 687 8.0- 9.5 875
235/50ZR18 101W XL 692 6.5- 8.5 825
255/55R18 109V XL 735 7.0- 9.0 1030
I ran staggered offsets with it still being 4wd. 8.5 +22 and 9.5 +25's. It was fine. Ijust ran 235/45s front and rear.
If your's is an auto, you will struggle to get a 9.5 +35 to fit. I run +22 and without camber arms it touched the coilover body on big bumps.
Manual, I'm probably just going to get them and if I have problems I'll change the tires so that diameter is the same.
Thank you everyone.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
