  • 1 month later...
Can we get an update on this one?
Only reason I ask is that I spotted this in the DRIVE ads at the top of the forum, the kms look to match what I remember the car having when it was first imported. Was it recovered in the end?
http://www.drive.com.au/used/search/detail.aspx?id=15027560&lid=15027560&s_cid=43310
  • 3 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
