Hey guys,
Ready to order pistons for an rb25/30 build i'm doing. Purchasing JE customs for the combo. Question is what compression do we want.... Want to run a gt35/40 sized turbo at around 18 - 20 psi to make around the 450hp mark at the wheels. Any one with a similar combo making similar power thats been running good for a period of time?
Looking to upgrade the camshafts also. What make of cam are you guys running in your cars?
Planning to use acl race series main and big end bearings, anyone heard anything bad about them or have a make that you would recommend?
Kind regards,
Tas
https://www.sau.com.au/forums/topic/353651-rb2530-build/
I decided to go 9.5:1 (Custom CP's) instead of the standard 8.5:1 as I plan on using high octane fuel at all times and possibly E85 down the road. Even if I have to back off the timing a little it will still help having a little extra compression.
As far as the cams go, I have gone with Tomei Poncams and matched them with Tomei Valve Springs. Depends how much the car is used for everyday stuff where you want to eliminate noise and smooth drivability to some point.
I used ACL bearings all round and wouldn't even look at anything else.
https://www.sau.com.au/forums/topic/353651-rb2530-build/#findComment-5668115
i see, we are thinking on using the 8.5:1 and the car will probably only ever run on 98.... i have performance springs (brand name) and am yet to decide on cams the car will be driven almost daily.. and i am gonna go with the ACL bearings also which tomei pon cams do you have ?
https://www.sau.com.au/forums/topic/353651-rb2530-build/#findComment-5668179
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
