Ok so I have no idea where I should post this, If i'm wrong please move it - or not a mod, tell me :).
I HATE how the rb25de and det neo engine covers look.. I cant stand the square box. I just despise it. But after taking it off, Im not a huge fan of how it looks underneath... it just looks a bit shitty imo. Im much more a fan of the longer rectangle ones, eg from the rb26's, I read a while back somebody saying they were actually a direct match and could be swapped, anyone confirm if this is true, where I could get one, and the process? :P thx
Also, even if the covers arent direct swaps, maybe there are some better looking ones for sale out there that im not aware of? I want my engine bay not making me sad every time I open the bonnet :(
https://www.sau.com.au/forums/topic/353803-rb25dett-engine-cover-question/
the rb26 cam covers fit no changes required... but if your using the stock cross over pipe I dont think they will work for you as the cross over pipe will foul on the cam covers, Im using a front facing plenum.
but if you want the timing belt cover to match seamlessly with the cam covers you will need the rb26 belt cover and backing plate, the rb26 covers are slightly more rounded and therefore the 25 belt cover doesnt match the shape.
I currently have the rb26 cam covers and valley cover on my 25 and Ive got the belt cover and backing plate there to install, I just want to get them all freshly powder coated first.... the belt cover needs either a whole or a lump modded into it as the rb25 as VCT intake cam end to consider, I'm getting some welding done on mine for this and also grinding off the rb26 raised letters...
there are a few threads about this already thats how I found out about it all...
Yeah i'm just cutting a little hole for the VCT to poke out of for mine. Shouldn't look to bad. Will paint the VCT black so it doesn't stand out to much and am going to sand back the "26" on the cover so it just says "RB".
Thats what im talking about mate! Looks great, Is that a R34?
i just shaved the blow by and moved it to the back like the 26
could just do that.... unless you really like the 26 covers
Wow thats insane mate, exactly what im looking at ... thank you!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
