Item:starcorp racing impul 18x8.5 +35ish and 18x9.5 +30ish
Age:unknown?
Condition:very good.. not RASH. tyres are 80-90% fronts and 40%rears due to camber wear.
Price:$800.. cheap....
To Fit: (What car) 5 stud!
Contact:pm, [email protected] and 0433290801
Comments:these rims are very good condish.. not signs of gutter rash. nice dished rears. ppl in adelaide are more than welcome to inspect. sit PERFECT on r32 and r33 from wat i have seen..
19inch White Starcorp Impuls DISH!!!
Excellent condition
19x8.5 front with 80% tread nexens 235/35/19
19x9.5 rears with 50% tread Nangkangs. 265/35/19
+35 offsets
$1000
Pics on the last page
PM or call 0433648021
cheers
Isaac
hey guys i have a R34 NEO TURBO + HKS DUMP PIPE for sale still in very good condition turbo no shaft play what so ever removed from car at
58,000km i was going to put this on my RB20det but have decided to go with a gt25/40 instead.
so quick sale $650 for turbo AND dump pipe! no really need for pics you all know what they look like =]
located in SA but could post at buyers expense
negotiable lol
Items: Custom Number Plates "ADRENLN" Black on Silver, Slim front, Standard rear
Item Condition: Rear plate brand new (not even on the car), Front has small dent
Extra Info:Costs $240 a year from Motor reg. Also, not sure, but I believe the name transfer fee is $24 (just off the top of my head). The plate agreement ends at the end of January so needs to be renewed before then.
Contact Details: PM me if ur interested
Price and price conditions: $450 for the Rights and the pair of plates.
Age:unknown?
are these black, white or chrome?
Hey all
Selling for a mate
Gunmetal A-TECH rims
post-54363-1225279824_thumb.jpg post-54363-1225279869_thumb.jpg post-54363-1225279907_thumb.jpg
Specs
17x8 front with 235/45/17 bridgestone tyres 80% tread
17x9 rears with 255/45/17 bridgestones 70% tread
5x114.3 pcd
around a +30 offset. (sit flush with 33 gaurds)
These are in as new condition and have quality tread.
looking for a quick sale
$1000
cheers
Isaac
R32 GTR WHEELS
repainted in gunmetal grey and bronze, look different colours in different lights! purple bronze grey etc.
specs 16*8s all round, have front around 80% tread rears 70%, only been on the road for 3 months!
saw a set of gtr wheels go for $600 the other week, which were just grey, so ill put these up for $650!
obviously they sit wicked on gtst r32 with no guard rolling camber e.t.c needed! looking for a quick sale as the skyline is begging for new shoes!
reason: time for a change, otherwise would keep them!
tyres: tread value above, brand are falken all round!
pm me or sms anytime 0431 308 333
Edited by Jonnyboy89
Brilliant Black '01 Aus Spec S15
41,XXXkm's
Standard everything except Buddy club Spec IV cat back exhaust (can choose either this or the stock exhaust), ANZ 18 inch rims, Nankang NS2s 90% tread, Jap spec steering wheel, trial front bar and Veilside side skirts.
Car has other features,
- immobilizer
- Rockford Fosgate head unit & VU meter (will disclose more info to keen buyers)
- Full 10% tint on the sides, rear and quarters glass tint
Car is a perfect example of a very clean black s15 that's in great condition and perfect for whoever wants a cruiser or a fresh canvas.
Cleanest example of an Aus Spec S15
Car comes with 6 months rego
Just had a wheel alignment
just serviced the car as well
Call for more info or PM.
PRICE DROP
$23500 ono!
0400 044 196
PRICE DROP
$20,000
Edited by AFTDRK
Item: AVS JAP rims for sale 17 x 8
Age: unknown but still sexy
Condition: good/very good only 1 rims with slight rash
Price: $1100 O.N.O
To Fit: (What car) sit nicely on 32 but will fit 5 stud
Contact: scott 0430 362 050
Comments: These rims and tyres are in good condition. Tyres are around 50 front and 40 rear running on nexon 17/235/45 both front and back
Make me an offer need the rims gone!!!!
THESE ARE GENUINE JAP RIMS
$1000 O.N.O
want these rims gone (make me an offer)
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
