mines triple flow cam cover baffle plates for rb 26 motor $275 BRAND NEW
stop blow by in the head, reduces the need for a catch can
brand new http://www.mines-wave.com/english/CATALOG/...AFFLE_PLATE.htm
"In case of the Nissan RB26 engine, the engine oil sent to the cylinder head remains inside the head without moving to the engine block due to its construction structure. Such oil remained inside the cylinder head will be discharged out together with the blow by gas since the oil will change its location according to the vehicle acceleration/slow-down & cornering. The Triple Flow Cam Cover Baffle Plate from Mine's has 3-layer structure, always maintains the gas passage. In addition, the gas/oil separator slows down the blow by gas flow and reduces the quantity of the discharged oil."
accidently ordered 2 pairs
$275
can meet in town weekdays for pickup
posted here, if any interest before posting in SAU classifieds
PM if interested
regards Jason
Greddy Turbo Timer with r32 harness - pretty much brand new $120
3 Drift Gauges (boost, water temp, oil pressure) $40 each
K&N pod filter - $20
how big are the boost gauges?
52mm or 60mm?
boost gauge is that in psi or bar?
Do you have the sandwhich plate for it?
PM me please
FOR SALE:
1992 Kawasaki ZXR750
Good condition, runs great
Has rebuilt gearbox and rebuilt carbs
Quick sale ... bargain $2000
Road registered or good for track bike
2003 GSXR600 Race/Track Bike
This has been my race bike for over a year. Selling due to downgrading to 250cc grade.
23,000kms engine. Engine is A1
2 sets of race glass
Tyre warmers and race stands
Full Leo Vince race system, Power Commander IIIr piggy back ecu
Showa USD fork conversion
Frame has been worked on and approved by Adrill Engineering
Raced for 3/4 of one season before I broke my shoulder. Only track days since.
Bargain $5,000 ono
Now the biggie! ...
2004 MV Agusta Brutale F4
Italian style and engineering with a 4cyl engine designed and built by Ferrari (hence the "F4")
Pure porn with carbon fibre parts (over $2,000), Ohlins adjustable shock ($2K)
Bike retails for $23K new
Fully rebuilt and customised with under 2K on the clock
$18,000 ... no dreamers ... no test rides.
PM for more info and pics
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
