R31Nismoid
I appreciate you looking into it, I am not sure who pulling the strings around here but I feel like a bit of a leper. Looking back I realise nothing have I done that would have got my blocked from the site. I am dedicated to resolving any issues that I may have caused, it seems the only way to get access back. I know I added a few people as friends, but I can stop. I know some things never seem to change but I can, I will get used to it somehow, you will see! I will master the whole forum thing one day, I suppose honesty is my only excuse. I think of SAU as my home, it would nice to feel welcome, home.
Jesus christ dude, man up a bit :blink:
I feel like i'm reading a Jodi Picoult novel.
Not in the ban list :)
It's either being blocked @ our ISP level as you are using a black-listed proxy or something...
Or some other issue at your end as it's certainly not at the forum level
Nor that one mate.
I'd say it's your end on both accounts to be honest if you say one is a school etc.
OR they could be using a certain type of blocked proxy, this has been known to happen and we cannot fix it from this end.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
