For sale: Here i have a standard airbox with snorkel for a R32 GTS-T for sale.
Item Condition: Good.
Price and price conditions: $130
Extra Info: Paid 150 for this damn thing off SSS automotive to pass a defect without the snorkel which was hard to find.. Most Decc stations wont pass you if you dont have the snorkel attached.
Pictures: post-38676-0-34655100-1298264908_thumb.jpg post-38676-0-44216700-1298265078_thumb.jpg
Contact Details: For faster replies please txt or call me on 0410 682 062,maybe text us first as i cant have my phone on me at work. Cheers Den.
Delivery & Conditions of Delivery: Will post for extra
https://www.sau.com.au/forums/topic/354680-fs-r32-gts-tstandard-airbox/
