patty_b Posted February 22, 2011 Share Posted February 22, 2011 Hey me and a mate was installing rear camber arms into my R34 gtt and got stuck. We did the right side easily but when did the left side the inner bolt got stuck and wouldn't come out. The thread of the bolt seemed to be stuck on that washer that has that wierd adjusting edge thing. If someone could help or recommend someone as paying someone a few hundred dollars is my last resort. Cheers Patrick Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/ Share on other sites More sharing options...
lunjiaow Posted February 22, 2011 Share Posted February 22, 2011 hammer and punch to get it out. Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5682947 Share on other sites More sharing options...
patty_b Posted February 22, 2011 Author Share Posted February 22, 2011 Not enough space I don't think might try jacking it higher to get under it Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5682961 Share on other sites More sharing options...
R DIRTY 3 Posted February 23, 2011 Share Posted February 23, 2011 The way i used to get it out in a case like that is to gas axe it. Not a great deal more options due to room. MUlti grips and a hammer etc + persistence MAY also be workable Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5684788 Share on other sites More sharing options...
bubba Posted February 24, 2011 Share Posted February 24, 2011 The way i used to get it out in a case like that is to gas axe it. Not a great deal more options due to room. MUlti grips and a hammer etc + persistence MAY also be workable Glad you don't work there anymore! Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5685462 Share on other sites More sharing options...
R DIRTY 3 Posted February 26, 2011 Share Posted February 26, 2011 Glad you don't work there anymore! lol Yeah i lost so many customers that wayy lol Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5689517 Share on other sites More sharing options...
bubba Posted February 27, 2011 Share Posted February 27, 2011 lol Yeah i lost so many customers that wayy lol Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5690075 Share on other sites More sharing options...
NA_Goodness Posted March 1, 2011 Share Posted March 1, 2011 paying someone a few hundred dollars is my last resort. I'd take it out for a few hundred dollars? Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5694503 Share on other sites More sharing options...
R DIRTY 3 Posted March 3, 2011 Share Posted March 3, 2011 Ill do it for $100. Please sign disclaimer below: All care....No Responsibility Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-5698459 Share on other sites More sharing options...
Muffins 34 Posted May 23, 2015 Share Posted May 23, 2015 (edited) Sorry for bringing up an old thread but i had this problem when installing my rear camber arms on my R34 GTT today. I found the problem was that the washer was not in the grooves it supposed to be in on the bolt. What you need to do is get the keys (one protruding piece from the washer on each side) lined up into the grooves again by turning the bolt till they line up. Then you can trying prying it off with a flat head screwdriver and wiggling it with your fingers or just smack the bolt with a hammer till it forces it off (keep in mind you do run the risk of damaging the thread. Luckily mine wasn't damaged). Its a tedious job but definitely do-able. Edited May 23, 2015 by Muffins 34 Link to comment https://www.sau.com.au/forums/topic/354843-r34-rear-camber-arm/#findComment-7538515 Share on other sites More sharing options...
