Howdy
I had 33gtr seats in my Stagea but they were quite a lot lower than the stock seats and I couldn't see the road properly. So then I had a special cushion made that's about 2½ - 3 inches high and I could see a bit better but then I had to have my seat pretty far forward still and I felt like a twit sitting that close to the steering wheel and I was sitting in the wrong part of the chair as in my head doesn't line up with the headrest properly etc. It just wasn't working :(
So I've now taken them out and put the stock ones back in but what I want to know is can you get higher seat rails? I've searched and found plenty of threads for people who are too tall for their cars and need the seats lower or moved back etc but not any about making them higher.
My other question is are all GTR seats the same height? I saw a car with 34 seats and I swear they looked like they sat the same height as a stock seat but I can't find the pic again to know for sure. My theory is that if the 34's sat higher could I then buy 34 rails to go on my 33 seats? I'm about 165cm so I'm no midget but I'm just too short to sit that low in the car.
I want to put these seats back in because they are a lot comfier but I can't until I sort the height issue out so any suggestions would be greatly appreciated.
Thanks!
Cheers
Jo :)
https://www.sau.com.au/forums/topic/354955-seat-height-too-low/
Hey jo.
You could always try getting some alloy blocks made up to act as sorta washers from the rails to the seat, to increase the height an inch or so. you wont get too much height this way as the higher you go the weaker it will get.
could try to weld and modify the 33 GTR seat brakets too. Apart from that you cant do too much as it will be too unsafe and weak.
as for the 34 GTR seats i think they are the same mounts and the same height.
good luck.
can you mount the seats on the stagea seat brackets?
mike
i wish i had that problem. :laugh:
making a seat go higher is a damn sight easier than making it lower. i had to get custom fixed rails knocked up by andrew and am to get low enough to be comfortable.
Mike - The stag seat rails don't fit the gtr seats unfortunately. We tried that pretty early on. And I'm kind of afraid to sit on a couple of alloy blocks but thanks for the suggestion :P
Hostile - are the modified rails legal do you know? The best thing about putting skyline seats in a stag is that as far as I'm aware, it's not illegal because the seat rails aren't modified.
cheers guys :)
I would imagine you'd need to engineer any changes to your rails as they'd need to be checked to make sure they comply with ADRs?
( *cant imagine being too small for a car, usually has the opposite problem* .. :( )
mine is too tall, needs to be bolted to the floor pan directly . DAMN sunroofs in R34..grrrr
use a phone book....kidding
Yeah - as much as I would have liked a sunroof in my R34 to match the one in my N14 SSS, I found it limited the headroom significantly - the reason I opted to avoid models with a sunroof..
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
