When I start my car in the morning to go to work or when finishing work in the afternoon - the engine seems to be slugish.
What I mean is that as I accelarate up to 80kmh or so the engine seems to be missing. I have noticed that this keeps happening until the thermostat kicks in and after that it is fine.
Someone has told me it could be a faulty temp sensor.
Anyone experienced this before?
Where can I find this temp sensor?
Please help !
CW
R32- GTR
https://www.sau.com.au/forums/topic/35509-cold-start-problem/
good point zoidberg... YAY your helping :D
if you are warming it up, how long does it take, does it warm up quick or take ages.
A dodgy thermostat will either not open at the desired temp (causing over heat)
or be stuck open all the time (making warming up take ages)
I wouldnt assume its the thermostat as this should only affect warm up times and engine temperature... AFAIK
a way of checking yr thermostat is working tho is to take of the rad cap, swtick in a thermometre and turn on the engine. iff all is well then the car should idle for a while with the radiater fluid temp staying steady, then it should heat up as the thermostat opens and starts letting coolant into the engine.
Mine does something similar. It feels like the timing is jumping around while the car is still warming up. Only does it when maintaining a speed or accelerating slowly. Idles fine or when under a bit of load. Then it will just suddenly be fine, like the computer switches from cold run mode to normal temp mode or something.
Definately either sensor or ecu related, not thermostat i think.
Definatelly not the thermostat - that is working correctly - Warming up doesn't take long. BHDave seems to have the identical problem as me.
I have checked spark plugs etc but the only thing left is the temp sensors if only I knew where to look.
Mine has always done the same.
When cold (especially in winter) the car develops what feels like a flat spot when cruising on a set speed or accelerating lightly.
Some times it starts to drive fine then it feels like some thing engages and the flat spot develops.
It only lasts for around 1km then dissapears.
Warm the car up for a couple of minutes and you won't notice it.
I'm suspecting it could possibly be some thing to do with the O2 sensors pre-heat function, as an O2 sensor doesn't work until it has reached a certian operating temp.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
