  • Replies 129
You Dont?
No.
What you doing in the Vic section?
There seems to be a distinct lack of astoundingly stupid people in NSW, so I have to look to Victoria to find some :)
No.
So you dont rag on people that make mistakes, yet you go into another states section looking for people that did make mistakes?
EDIT: Dumbed it down for Merli.
So you dont rag on people that make mistakes, yet you go into another states section looking for people that do?
Looking for people that do? Do what? Rag on people that make mistakes? English much?
Yes, that's right... I came into the Victoria Forums just to look for people that rag on people that make mistakes... ugh.gif
Thanks for playing VIC Forum Police though, because you know......... Only people who live in Victoria are allowed to read this section :)
Anyway, this conversation with you is getting boring... You have nothing interesting nor intelligent to say. Here ends my replies to your valuable contributions to this thread... Thanks for the chat though :D
i care what he says  :)
merli posts the most interesting and entertaining replies on this entire forum
sometimes.
other times he posts bullshit.
Good thing he edited his post in the ideas/feedback section.
It proved that he was nothing omre than a ill-informed loud mouth
sometimes.
I know when to shut up............ sometimes :)
but u havent yet.
That's because you keep replying with stupid, petty, immature whinging posts with no substance and no aim other than to try and call me out....
At least my posts are a) replying to useless posts like this one I'm replying to; or B) commenting on the actual thread subject.
Guest INASNT
oh dear me.. here we go with the keyboard warrior line again  :)
The pic is to say that this thread has no where else to go but just pointless bs to each other. He farked up and he is paying for it, simple as that.
Merli
Read above, i have better thing to do than edit jpg's and post em up.
How did I **** up? By calling this R34GTT guy a brainless moron? :) :)
And I'm paying for it by being the brunt of your senseless and immature posts? :D
I don't think you realise how stupid you're looking right now hs.gif Keep posting Denjam... You're doing Melbourne proud with your intelligent posts :)
Guest INASNT
dumbass, R34GTT ***ed up and is paying for it.
Guest
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
