OK, I dont really know sh*t about turbos :-} but have been reading recient posts to try to build up my Knowledge.
From what i have read the GT2530 is a good responsive turbo that can make about 250rwkw.
My current perf mods are:
3' turbo back zaust,
zaust cam gear,
cold air box with pod,
FMIC,
PFC Pro,
ceramic button clutch,
supra twin turbo fuel pump jap spec (was told that they flow better than GTR ones by far, maybe somebody can varify that?)
NGK irriway7 plugs.
I think thats it.
I would like a turbo that doesnt lag any longer than 3,500 but still comes on boost hard. I plan to get new injectors and a z32 afm in the future but not for awhile. My car currently makes just over 200rwkw on the standard turbo, what turbo whould make a good replacment for me?
any advice would be great thanks.
https://www.sau.com.au/forums/topic/35589-which-turbo-for-me-help-please/
try gcg turbos 0418645461 in canberra they do a high flow on yours whilst there at it, it gets new roller bearings new steel exhuast wheel so big boost is possible(ceramic wheel wont shatter)and apparently will do just as good as 2530 and costs bugger all in comparision
you wont need a fuel pressure reg if you are doing injectors.
probably better off with a 2535 or 2835 than 2530, as it will make the power a bit easier.
$1550 is a bargain for a second hand HKS turbo, even if it needs rebuilding it will be a better price than new. you can also sell your stock turbo. It will be a good idea to upgrade the pipe from AFM to turbo to, so anther $150-200 there, then similar may be needed for turbo to cooler. Oil and water lines, $300 or thereabouts. Injectors around 1K. AFM around $350 with a plug.
be ready to pay around 5-600 for a full remap with the injectors too.
good luck
I have started to think that if I am going to spend around $4000 on a 2535 setup then I may as well save up a bit more and go for something like a GT3035 or something alike...
Does anybody out there have a setup like this? & what are your experiences with it, eg power, boost, spool up time and so on & what price range would I be looking at for this?
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
