I recently installed my adjustable cam gear, and got it tuned. I was not happy with the service i was given, and when the tuner was dialing it in, he told me that 1 notch is 1 degree. Is this rite? I was told by many sau guys that 1 notch on the cam gear is equal to 2 degrees crank. anyway when i was told this i instanly started to worry.
So ill get to the point. Lookin at the cam gears on the engine, ie straight ahead, the exh cam gear is 2-3 notches to tdc. Now does this equate to 2-3 degrees? or 4-6 degrees?
Cheers, ill try post a pic, but my camera is dodge and doesnt pic up little details too well.
Thanks
Dean
https://www.sau.com.au/forums/topic/35613-what-are-my-cam-gear-settings/
What brand of cam gear is it??
My first thought would be 2-3 marks (notches) would be 4-6 degrees.
I know the Greddy and the HKS ones are like this (the greddy one actually said it in the instructions).
I think someone mentioned that 4 degrees was about 1.9mm movement.
J
Yepp, that looks right.
The motor turns in a clockwise direction when your looking at the front of the motor.
So looking at the picture you can see that the cam is trailing (retard) the cam gear/belt.
It's hard to say, but the amount it is moved by looks about right for 4 degrees retarded.
J
Dean, pretty sure mine is set 4 notches back for 4 degrees (from memory), its a HKS one. yours looks advanced to me. If its retarded, the internal part of the gear should be rotated to the left, so the cam is set back from the center factory setting. By moving it to the right, it means the centre is forward, or advanced.
It is retarded. The pulley turns clockwise, and the cam that is attached is now lagging slightly behind the pulley, so everything happens just a bit later.
The pulley has 48 teeth which is 720 crankshaft degrees. Each tooth on the belt is fifteen crank degrees. If you look you will see it has been retarded about one third of a tooth. Pretty close to four degrees I would say.
The pulley has 48 teeth which is 720 crankshaft degrees. Each tooth on the belt is fifteen crank degrees. If you look you will see it has been retarded about one quarter to a third of a tooth. Pretty close to four degrees I would guess.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
