  • Replies 192
MJ - I did a guesstimate of 2 hours but Nexus9 says we should be able to do the run in ~1 hour as he has done that route"many a time" It's apity you cant finish work 30 mins early, or what is the earliest you could make it to BP Yatala, I was planning on leaving 9pm to 9:30pm so if you can make it there at like 9:45pm what does everyone think can we wait around a bit longer for MJ?
i will try and get work off an hour or 1/2 hour early it really depends how busy i am that day. If i cant dont wait up for me though im too slow for mountain runs anyway and ill just meet you guys at coomera. So if you leave around 9ish and ill probably get to coomera about 10, as ill go home and get changed while you guys are cruising and ill meet yas there.
Negative Genesis.. I will NOT be a Briz Starter..
Uhmm.. does anyone know of anyone who needs a seat? because like .. im kinda gettin over riding by myself ..
and i havnt picked up any car ****s yet :D
Not sure if your interested but i know someone that would be interested in coming for sure, he loves skylines but never gets to come on cruises.
pm me if your interested.
Ben :wavey:
Just got the OK from the boss to borrow his really expensive digital camera tonight, so I will endeavour to take a pic of everyones car, so that no one feels unloved, or for those who want some really nice shots, why not stop along the M1 there's a big overpass, I think it is the hope island/sanctuary cove exit anyway that would be a great spot for some drive by or some "other" type shots :D *cough*
15 people confirmed + all those lurkers.
PLEASE NOTE twoquik has pointed out a serious error in the directions with the pictures, please use the link provided in the PM _IF_ you are printing out your own copies to bring!
Yeah to those who are coming, if it is not raining, we might be the first people, other than slip/Gary to see the QLD SAU Member T-Shirts :) _MIGHT_ if it is not raining, and it has not started raining, but I am certainly hoping it does not. This is what it looked like yesterday and we didnt get a drop out of it, so hoping it will be the same tonight :D
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
