Hi i have the followings up for sale:
Hypergear ATR43G3 .63 rear turbo
direct bolt on for r33 gtst. comes with high pressure actuator.
put the turbo on last year late November. I left the country for 3 months since then so the turbo has seen literally less than 5000km's
The turbo is still on the car will pull it apart when deposit is paid.
$900
Apexi PowerFC to suit r33gtst both S1 and S2
No handcontroller.
cant get the serial number it is still running on my car so its 200% working
has been tuned with above turbo and z32afm.
$900
R33 GTST S2 boot spoiler in white
$50
KTS Japan Steering wheel with bosskit to suit R33GTST
$160
All items are in Melbourne can post at buyer's expense (spoiler excluded)
contact details: reply here // pm // [email protected] // 04 6886 0911
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/
hi turbo is internally gated. the turbo is almost new (<5000km's and only been driven on the street , never seen rev limiter) but its still on the car so I cant exactly comment on the shaftplay but i would expect none since its basically new.
its rated at 280~300rwkw (~500hp).
cheers
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/#findComment-5707876
thanks for the kind words.
sorry for the delay at the workshop tho.
wheel and boss are sold too.
still got:
r33 s2 spoiler (white) $30
2 x works 3" to 2.5" silicon reducers $20
also a z32afm in working condition just got it off from the car today
as shown in the photo theres a crack at the side of the AFM cover but doesnt affect its performance.
it has been in good working condition till the second its taken off.
ill also throw in a 3" intake hard pipe with the z32 to suit r33 RB25.
$200
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/#findComment-5726146
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
