Hi i have the followings up for sale:
Hypergear ATR43G3 .63 rear turbo
direct bolt on for r33 gtst. comes with high pressure actuator.
put the turbo on last year late November. I left the country for 3 months since then so the turbo has seen literally less than 5000km's
The turbo is still on the car will pull it apart when deposit is paid.
$900
Apexi PowerFC to suit r33gtst both S1 and S2
No handcontroller.
cant get the serial number it is still running on my car so its 200% working
has been tuned with above turbo and z32afm.
$900
R33 GTST S2 boot spoiler in white
$50
KTS Japan Steering wheel with bosskit to suit R33GTST
$160
All items are in Melbourne can post at buyer's expense (spoiler excluded)
contact details: reply here // pm // [email protected] // 04 6886 0911
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/
hi turbo is internally gated. the turbo is almost new (<5000km's and only been driven on the street , never seen rev limiter) but its still on the car so I cant exactly comment on the shaftplay but i would expect none since its basically new.
its rated at 280~300rwkw (~500hp).
cheers
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/#findComment-5707876
thanks for the kind words.
sorry for the delay at the workshop tho.
wheel and boss are sold too.
still got:
r33 s2 spoiler (white) $30
2 x works 3" to 2.5" silicon reducers $20
also a z32afm in working condition just got it off from the car today
as shown in the photo theres a crack at the side of the AFM cover but doesnt affect its performance.
it has been in good working condition till the second its taken off.
ill also throw in a 3" intake hard pipe with the z32 to suit r33 RB25.
$200
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/#findComment-5726146
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
