For Sale
R32 GTR 328rwkw
Full respray grey, 6 point cage, forged pistons, shotpeened rods, head work, cams, apexi power fc, garrett 28/60 -5 turbos near new, apexi intakes and pods, 700cc sard injectors, 040 pump, 100mm thick custom cooler, hks triple plate cutch, apexi coilovers, 2 way diffs front and rear. turbo back exhaust, drift wheels, 235 on front 255 rear. custom whiteline suspension, also has front and rear sway bars. apexi gauges on pillar, apexi boost controller.
i have probably forgotten a few things, alot of time and money has been spent on this car. made 328rwkw on 21 psi, have dyno papers.
$24,000
call 0421 173 880
Edited by laspy
https://www.sau.com.au/forums/topic/357016-for-sale-r32-gtr-328rwkw/
  • Replies 59
- Full Respray in gun metal grey using quality standox paint
- R33 GTR driveline
- Engine rebuilt forged pistons and shotpeened rods
- Head full port and polish with HKS cams and JUN valve springs
- Gearbox rebuilt and has HKS Triple plate clutch
- Garrett 28/60 -5 turbos
- Apexi Power FC
- Sard 660cc injectors
- Bosch 040 fuel pump
- Z32 Air flow meters
- ATS 2 way front and rear diffs
- Custom 100mm cooler
- 3 1/2 inch turbo back exhaust
- 6 point Jap cage in black
- Apexi N1 coilovers
- Custom whiteline suspension
- Front and strut braces and sway bars
- Apexi air pods
- Hard pipe kit
- Greddy oil and boost gauges on pillar
- Nismo 320km cluster
- Short shifter
- Custom catch can
- Slotted rear rotors and crossed front rotors
- Greddy Profec B boost controller hi/low setting
- Turbo timer
- Dished drift wheels 245 front 255 rear
- Alpine head unit
- painted engine covers and polished turbo pipe.
Alot of time and money has been spent on this car. Very sad to see it go,
havent got the time for it anymore. engine is still brand new, Great car to
drive. Made 328kw atw on 21 psi, have dyno papers.
$26,000ono
call 0421 173 880
Edited by laspy
few things i missed, here is a revised write up of the car. still for sale
BODY
- New windscreens and rubbers
DRIVELINE
- R33 GTR engine
- Engine rebuilt
- CP forged pistons
- Shotpeened rods
- Race bearings
- Linished and balanced crank shaft
- ARP main bolts and head studs
- Cometic head gasket
- HKS cams
- JUN valve springs
- Braided lines
- Apexi Power FC
- ARC intercooler
- Custom intercooler piping
- Z32 air flow meters
- Apexi air pods
- Hard pipe kit
- Custom catch can
- Turbo back exhaust
- ATS 2 way front differential
- ATS 2 way rear differential
- R33 Gearbox
- Rebuilt
- HKS triple plate clutch
SUSPENSION
- Front and rear strut braces
- Front and rear sway bars
- Slotted rear brakes
- Cross drilled front brakes
COSMETICS
- 6 point jap cage in black
- Greddy oil gauge
- Greddy boost gauge
- Pillar gauge holder
- Short shifter
- Aftermarket gear knob
- Turbo timer
- Dished 17" drift wheels
- Alpine head unit
- Painted engine covers
- Polished turbo pipe
- Nismo oil cap
- Nismo Radiator cap
- New battery
- T-bolt clamps
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
