Dual Cab Rodeo LX "98" 3.2 V6 2wd / 1via drift car wanting to swap both for 1 phat streeter or $$
DRIFT TECHS NOT INCLUDED IN SALE!!!!
WILL COME ROLLING ON 17" WHITE MESHIES ALSO GET A PAIR OF 18" LENSO.
Condition: Used
Reason for Selling: moving away sale
Asking Price: 18000
Delivery Methods: PickUp
Contact Info: millsy 0415499115 call or msg anytime
Extra Information:
ok up for sale i have my daily drivin rodeo dual cab, i also use this to tow my drift car to meets on the odd accation.
if interested ill throw in my drift car as a package deal for someone that wants to drift tow car and track car.
i am intereseted in swapping cars for just 1 phat streeter.
its a Holden TF Rodeo LX "98" 241km on the clock, 2wd, 3.2v6, 5spd. 30 sep "11" rego NSW
silver paint, in good condition besides the few minor blemishes, and a couple of dints.
power steer, ac just been regased and new compressor fitted, by previous owner.
starter motor just been rebuilt.
dash mat, no cracks at all in the dash.
interior is in good condition, only 2 things missing in it, (ash tray & back passenger head rest.)due to having a child restraint fitted to it.
always serviced, never missed a beat. excellent tow car.
hayman reace heavy duty tow bar.
soft torneau cover.
also can come with a full set of tradie racks and nudge bar with hella spot lights.
pioneer head unit, 6" pioneer speakers front and back doors.
And the drift car. 1via (still registerable) Also comes with shit loads of spare parts......
making 260kw @ 14psi. 463nm of torque.
avcr set from 14psi, 21psi and 25psi. so its got plenty more power.
Head work:
-ARP head studs.
-Waggott Cams, inlet 276 exhaust 266.
-Crower heavy duty springs.
-Valve regrind.
-Valve stem seals.
-New rockers.
-Cam cap tunnel line bore & bearings.
-Tomei solid lifters & shim kit.
-HKS rocker stoppers.
Brake mods:
-Front 5stud conversion with s14 hubs.
-Front 4spot callipers & ventilated disks.
-Front endless brake pads.
-R32 GTR double diaphram brake booster.
-Rear R33 5studs conversion.
-Rear R32 GTR 2spot calliper conversion.
-DBA slotted disks.
-Grex rear brake pads.
-R32 GTST handbrake cable.
-Earls braided brake lines all round.
Wiring:
-Gold terminals & dry cell battery in box in boot.
-batery isolator switch (located at rear of vehicle)
Suspension & Steering mods:
-cusco alloy castor rods.
-HSD HR coilvers all round.
-S14 steering rack (longer).
-Non hicas rear end cradle.
-Nismo lengthened wheel studs.
-Cusco strut braces all round.
-D-Project rear camber arms.
Enigine bay mods:
-Twin 12" thermo fans.
-koya aluminium radiator.
-N/A 60 mm throttle body.
-Pitwork belts.
-GReddy plennum.
-Billet fuel rail.
-680cc injectors.
-Custom intercooler pipes.
-HKS SSQ bov.
-Sard fuel pressure regulator.
-All speed flow fitting & braided lines.
-X-Force stainless steel low mount manifold (powder coated by competition coatings).
-HKS 2530 turbo.
-HKS split screamer, staright through 3" exhaust, twin pipes at rear screamer out side skirt.
-Drift oil catch can.
-Custom power steering reseviour.
-Engine dampener.
-Drift 4" pod.
-Bosch coil packs.
-trust sump.
Drive line & exhaust:
-Rebuilt gearbox.
-Nismo 1.5 way lsd.
-R33 GTST driveshafts.
-Apexi N1 straight through 3" exhaust
Interior:
-Micro-tech LT10s ECU.
-Sparco deep dish wheel.
-2x Bride fixed back bucket seats.
-sabelt 4 point harnesses
-Trust gear knob.
-Drift button.
-Apexi AVCR.
-Apexi Pen Turbo Timer.
-Apexi EL2 white face gauges, oil pree, oil temp, wat temp, boost.
-ignition missile switch
-fuel pump missile switch.
-toggle wippers, lights.
-push button start.
Body:
-2 pac Kawasaki Green paint, gloss black roof, boot and bonnet.
-BN sports 2 kit, front bar, skirts and rear bar.
-fibreglass vented bonnet.
-full set of 17"white mesies and pair of 18" lenso.
MIGHT HAVE FORGOT SOME MODS......... THIS WAS JUST OFF THE TOP OF MY HEAD.
NO TEST PILOTS.........
if keen call or msg anytime on 0415499115
located in taree nsw.
KEEN ON SWAPPING FOR A PHAT STREETER........
BUT JUST BRING ON THE OFFERS YOU NEVER KNOW WAT I WILL SAY YES TOO.
https://www.sau.com.au/forums/topic/357208-1via-drift-car-dual-cab-rodeo/
  • 4 weeks later...
update: couldnt sell!! stripped green 1via. now selling a complete rolling shell. $1800 ono comes wit 4 stud, king springs front, cut rears, full kit, fibre glass bonnet, bucket seat. (not bride.) rolling on s13 stockies front and steelies rear. very cheap track car, only thing needed to put back on streets would be steering column and climate control, probly carpet.
call or msg if interested 0415499115
located at taree NSW
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
