R33 GTR front bar $130
drift steering wheel $140 with boss kit, or without boss kit $80 for steering wheel only
Boss kit for $60
window wipers for front and back $25
drink holder for underneath CD player $15
black smokey side indicators $50
front indicators $40
back shelf speaker holder air vents $10
front driver side seat belt buckle $15
back seat belt for middle section including buckle $25
Middle drink holder $15
nissan skyline R33 floor mats no drive side mat $30
R33 boot carpet to hide back lights $10
R33 boot carpet right side carpet $ 5
Monza mspec seats $500
R33 S1 stock seats $300
R33 back light lift side cover $15
O.N.O on most stuff
call or text or PM me PH:0413421012
post anywhere in AUSTRALIA at the buyer own expensive. Thanks
post-81807-0-95720300-1299553508_thumb.jpgpost-81807-0-96838000-1299553489_thumb.jpgpost-81807-0-83329900-1299553472_thumb.jpg
https://www.sau.com.au/forums/topic/357302-lots-of-r33-parts/
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
