im still in. so BP's southbound at 7. then head to carseldine from there :) even if chris isnt joining us, im keen for at least a small drive :thumbsup:
sounds good Joe, look forward to fiddling a kit out of it, im sure all the parts are generic enough and can be persuaded into place and shape. if they are steel i can weld that too.
I 'should' be at the bp at 7, however,
Im being pushed by my contractor to get ahead of my current list (clients web site) because i will be netless for a few days. So depending on how im going will depend on my rocking up :P
FMIC - no stock, coming from 'japan', not happy about waiting, and the fact that they have 9 in stock according to ebay. I will be asking for free stickers!!!!
not good, should have told you before buying it, that way you would have had a heads up, should ask for a discount.
oh also, managed to source out a set of 18" rims, very much like what i used to have on the little beast, just need to save up for it (blokes being nice and is willing to wait for me to save it up).
anyone know much about BBS rims?
fark......
i wont be coming either.....very late notice. but the better half has been doing very poorly of late and i kinda need to stay home. shes been home for almost 3 weeks now....and still no answers as to whats wrong.
just thought i'd let you lads all know, took my 32 out willowbank last night. Did an 11.4 @ 123mph. Still a little more left in the current tune, spun a decent amount off the line still.
For those of you who don't know, its 040LAH.. the white 32 from the happy laps on the weekend.
:thumbsup: nice. but i wasnt at happy laps :(
on another note. seeing as i couldnt go out last night. anyone keen for a drive to go see the westies tonight??
sry Chris, not heading out tonight. after dinner and playing with my new phone, i lost track of time and im just too lazy to get moving. twas an idea i had earlier....but its faded.
on another note, i have my new phone Xperia Play. so far so good. not missing the Iphone at all...yet
well this leads to the question of why weren't you at happy laps? :P
twas a matter of i needed new brake pads (which i still havent got), and i was too lazy and busy to get it done that week beforehand.
i'll def be there for the next one tho, plenty of time to sort out those brakes. :w00t:
Are you just going to get standard pads? when i get my rotors im still unsure of what pads to get.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
