FYI Boost cruising meets are gay, It's more bogan than a Commodore packed full of vb drinking mullet rocking Cabbo natives listening to AC/DC while yelling out the window about how they can cut "Heaps sic skids" in there mum's hand me down VN.
Take it you went on one
On another note, is there anyone from the northside going to motokahna this weekend?, if so can you please let me know as I was thinking of a small cruise down to it
No, was going past Autobarn here and spotted the even they were on about over at Boost Cruising took one look (from the lights above the shop) and kept going
Well I have never been on a cruise with boost cruising, and never plan on going, I feel there would be too much cop attention, as well as too many dickheads (sorry for the bad language)
Thought u were going inside, don't turn to the darkside now clint..
Who wants to follow some p platers around in cars with holes threwout to make it sound 'like boss' anyway :S
On a side note, anyone ever had experience with intercooler water sprays? to 'cool the cooler down'.
not me personally, but i know someone who did it to there N16 that they boosted, he used a washer bottle to hold the water and used the pump from the bottle to inject the water, as for the delivery system i think he got a high pressure nozzle to act like a injector, and had it just before the throttle body
i think it ended up spraying a very fine mist to cool the air
from what i remember reading back in the day on fullboost they used a pressure switch so it only turned on over X boost otherwise you would empty the container in 5 seconds...
the biggest issue was getting a fine enough mist using XYZ pump and XYZ nozzle so it doesn't just drench the cooler as that is TOO much water and ruins the cooling effect as the water just sits on it
There are two Item's one being a wiper like nozzle and bottle that spray the intercooler it'self or the water methanol mixture that injects into your intake, Neither are really worth spending money on until your making power.
I am looking into water / methanol injection at present to see if I can run it with my current config and steal another 100hp out of my car (with cams and exhaust cam gear)
Wouldn't bother dude with the water/meth setup. Don't like the setup they come with. Don't know if you remember, but that green 33 that was at work had one in it and the bottle leaked all the time. From what I could tell it was a brand new kit to that the owner installed. I have the C02 sprayer on my car and have not done any test to see if it makes any sort of a difference. As for the water sprayer idea, go to bunnings or a garden shop and buy yourself some irrigation nozzels, get some vac line, or buy a universal washer bottle kit from Repco and use the line and away you go.
I came 4th in the sq novice division of the MEASQ Contest down in Enogera tonight,
Blew 8 fuses in the amp (configured way wrong by installer) so that is being fixed tonight / tomorrow, On the plus side it made 135.6 DB on the in car DB meter before it blew the fuses.
Guy doing it said it should do 140 pretty easy once i fix the screw ups.
Damn eh, let me know how the CO2 goes when you get a chance to test it (with the amount of work you have on I will have blown and rebuilt my engine before you get a spare min to test it) I'll let the idea sit for a while and wait and see what actual results people are getting before I pursue the Idea or go another route.
Hahaha. Yeah...... I know. It will be happenning soon though once i sell the pulsar it'll be off the road and getting done.
Nice,
I may have need of your services to do some voltage testing on this sound system of mine, and check the earthing in the boot. I had a slight bit of alternator noise during the sound off 0 bit track.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
