popped out to the test and tune tonight, saw a 4 door r34 and a 2 door r34 both run around the mid 14s from memory
saw an old school capri lose it and JUST miss the wall at the pointy end of the track.. was like the 3rd run of the night.. apparently dropped some water but that was all thankfully
and a stupid fast hayabusa drag bike(super stretched rear end etc) collected 2 timing markers at half track luckily nothing else happened to him
couple of pop and crackle and crunch noises from a couple of cars but overall it was a good night
not as busy as previous years for the good friday tnt but with a street shoot out event on tomorrow maybe half the fast cars held out till tomorrow
Well car is freshly serviced ( thanx John) tyres checked and boot loaded ready to go to Hervey bay for 5 days of camping. First long trip in skyline since I've had it so praying it all goes smoothly. The best part is the kids will all be in the captiva so 3-4 hours of peace lol. Can't wait
my wifes parents went over to Japan for a wedding and we asked them to pick up some Domokun stuff
turned out one of the only places you can get it is the NHK TV Character store which is SUPER expensive
they brought us back all this stuff
the cloth underneath opens up to like a table runner sort of length but is just a fabric, we are going to get it framed as its pretty cool
indeed we did, in carseldine :thumbsup: and yes, prob this thursday
YAY for Domokun randomness!
yep we did. pending panel shop and QT I may bring the new toy out.
New exhaust bodo? How much she set ya back? U fitting it?
yeah man, it cost me $350. its an old HKS Priest......which as it turns out is a 3.5inch system (found this out after buying a 3inch gasket for the center join), but has 2 mufflers and a resonator in it, the guy i got it off showed me a vid clip he took of his GTR before removing it, sounds good :)
thinking of just getting one of the 3 inch catco or Xforce cats from JJR to complete it. should be more than enough flow for my car as it is atm.
catback zorst is on, very quiet maybe too quiet. sounds nice inside. and no drone at any speed.
happy laps was good, even had my brothers old '56 beetle out there :)....till it spat the oil filler cap..lol.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
