considering getting a 4x4 as owning a car like ours is proving to be a hassle with all the young dickheads buying them now and doing skids / racing in them.
yes please buy another big 4wd soccer mum tank blocking the suburban roads ;) ;) ;) j/k :nyaanyaa:
33 is still better than a maxima :P
^^this man knows his stuff
Why would you go from a 34 to a 33? :P
I see what you did there
It will be my weekend car so I can go camping and finally buy a boat.
Cant argue with that. But you really should bring your car out more often
done.
Awesome idea.
Impressive...but god dam is it ugly....
This.
Well hi northsiders :P only just found this thread. I like the idea of the amount of powah the Juke R puts out but is ugly as fark.
Northsiders have had their own whoretown for a while now. And yes,the Juke-R is fUgly.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
